Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Starting problems what the hell?
Old Jun 27, 2008 | 01:43 PM
Revolver123's Avatar
Default Starting problems what the hell?
05 civic ex.
Raining hard today. Went to start it, not only did it have to crank a lot longer to start it seemed like it was a really hard start. I don't know, it made a weird noise while cranking toward the end. Could this be the starter or fuel pump going?
Old Jun 27, 2008 | 01:45 PM
Curiouz_G's Avatar
do you have a CAI?
Old Jun 27, 2008 | 03:25 PM
Default Re: Starting problems what the hell? (Revolver123)
No completely stock. Has started fine the last few times but that rough start still scares me. If it does it once it will do it again.
Old Jun 27, 2008 | 04:19 PM
DsevenEm2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolver123 &raquo;</TD></TR><TR><TD CLASS="quote">05 civic ex.
Raining hard today. Went to start it, not only did it have to crank a lot longer to start it seemed like it was a really hard start. I don't know, it made a weird noise while cranking toward the end. Could this be the starter or fuel pump going?</TD></TR></TABLE>
Alright, here we go:
Do you have any CEL (check engine lights)?
Could you describe the "weird noise" you heard at the end of cranking?
How long would you say cranking did it take to eventually start?
When you put the key in, and put it in the ON position (right before ignition), do you hear a quiet buzzing noise? (go in your car, windows up as quiet as possible, turn the key ON and listen for a 2 second buzz, like a small motor running).
Done anything with your fuel lately? Run out of gas, octane boosters, that sort of thing?
Have you checked battery voltage? Is your battery good? Has it died lately? Take it to autozone to test the battery if you dont have a voltmeter.
Check under your hood and dash in the fuse panel and make sure all your fuses are in completely, that none are loose or any screws holding on Main Fuses are missing. Usually this wont ever happen by itself, but it never hurts to double check anyway..
Thats about it for now.. answer those and get back to me. Feel free to PM me if you want.. but we can answer them here too
Jade LaMontagne
Aug 30, 2018 08:43 AM
surrealx
Jul 24, 2011 11:28 AM
Nooch
Dec 24, 2010 05:36 AM
SupraRXZ
Feb 20, 2006 01:11 PM
Ibuprofen
Sep 25, 2001 04:46 AM
