windows don't work on 90 accord
Old Jun 25, 2008 | 07:27 PM
donnybrasco's Avatar
Default windows don't work on 90 accord
i just replaced the engine in a 90 accord with one from a 91. i rolled the driver window down so i could start the car without opening the door. i then changed the temperature sensor because it was bad. now none of the windows work. i'm pretty sure its coincidence it happened that way. i checked the fuses and everything looks fine. i checked the relay under the hood. i swapped window switches. nothing. also the temperature gauge stopped working after replacing the temp sensor. and the tach and speedo don't work now. all wiring appears to be in place though. if anyone has an idea please help.
Old Jun 26, 2008 | 05:07 AM
Lancer03oz's Avatar
Default Re: windows don't work on 90 accord (donnybrasco)
check the under dash fuse box. it will be a 10 amp fuse that will most likely be blown. it controls, windows and instrument panel. i think its labeled back up light.
Old Jun 26, 2008 | 05:45 PM
Default Re: windows don't work on 90 accord (Lancer03oz)
yep, that was it. everything is working now. thanks for the tip.
thekingofvtec
Jun 12, 2018 02:29 PM
Jeseph
May 9, 2018 01:03 PM
shinneh
Feb 6, 2012 02:56 PM
Harvz
Jan 4, 2005 06:42 AM
