Another Idle Thread...Please help! *Searched*
Old Jun 25, 2008 | 05:37 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Another Idle Thread...Please help! *Searched*
Well, I have a B16 in my CRX... It was running great with the GSR throttle body, but i found one for a DelSol VTEC. I Installed it last night, and started it up and everything was fine.(Only started it for 2 min to make sure nothing was leaking.)
This morning I start it up, and it was normal. I let it warm up and started driving. When I got to the stoplight by my house, the idle was bouncing from 650-1500 rpm constantly.
I used a new gasket, torqued to specs, bleed the coolant, and installed everything correctly.
Would this be a sign that the TPS or MAP sensors are bad? I put 50 miles on it today and dont have any CEL's. Car is converted to OBD-1 running a stock USDM P30 ecu.
Old Jun 25, 2008 | 06:43 PM
AK_CRX's Avatar
Default Re: Another Idle Thread...Please help! *Searched* (Dc4iNtEgRa)
you probably lost a little coolant when you put the new one on. Did you add coolant to top it off when you were done? Low coolant won't let the iacv work right and you'll get a surge. Since the iacv is the highest part of your coolant system it only takes a small loss of coolant to give it problems. You map and tps would cause more serious problems and a definate cel if they were the culprit.
Old Jun 25, 2008 | 08:06 PM
grog's Avatar
total searched my a$$, search the archives, search post bodies, try different terms, look in the faqs for Idle woes.
Learn to search better
Old Jun 27, 2008 | 12:18 AM
Dc4iNtEgRa's Avatar
Default Re: Another Idle Thread...Please help! *Searched* (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote"> Another Idle Thread...Please help! *Searched* (Dc4iNtEgRa)
Thanks Bro .... I searched and found a hundred threads and none of them had problems like mine...
Start up= FINE... Cold 2000 rpm- warm 700 rpm...
Engine at 190' , hit the gas peddle = fluxuating from 650 to 1500 rpm...
Coolant is topped off, and bleed. It has somthing to do with the TB, because it was fine before I swapped it out.
IDK? Maybe I drank too much this month?
Old Jun 27, 2008 | 02:49 AM
traxxasx's Avatar
Fitv
Old Jul 1, 2008 | 05:55 PM
Dc4iNtEgRa's Avatar
Default Re: (traxxasx)
OK, I put the GSR throttle body back on, and everything was normal...Now I noticed my GSR throttle body has 2 ports before the butterfly... The new one I put on only has 1 port going to the FITV... Would this have anything to do with it?
Old Jul 1, 2008 | 06:14 PM
Dc4iNtEgRa's Avatar
Default Re: (Dc4iNtEgRa)
Also, when I plug the hole on the new throttle body for the FITV, it idles normal...
Why does one TB work, and the other one has issues?
Old Jul 3, 2008 | 04:36 AM
Dc4iNtEgRa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa &raquo;</TD></TR><TR><TD CLASS="quote">OK, I put the GSR throttle body back on, and everything was normal...Now I noticed my GSR throttle body has 2 ports before the butterfly... The new one I put on only has 1 port going to the FITV... Would this have anything to do with it? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa &raquo;</TD></TR><TR><TD CLASS="quote">Also, when I plug the hole on the new throttle body for the FITV, it idles normal...
Why does one TB work, and the other one has issues?</TD></TR></TABLE>
Old Jul 3, 2008 | 06:28 AM
90teg91hatch's Avatar
ha try this... im currently having a idle problem myself... swicth your tps and map sensor plugs... thats what fixed mine... you might have them hooked up to the wrong sensor... easy mistake
Old Jul 10, 2008 | 05:30 PM
Dc4iNtEgRa's Avatar
Default Re: (90teg91hatch)
Ok, i found out that my TB is a 96+ because it doesn't have a FITV.
There is still 1 coolant line going from the head to the TB, and 1 from the TB to the IACV.
Would bypassing the the TB all together and running 1 line from the head to the IACV fix this problem?
Thanks Alex
Old Jul 10, 2008 | 06:26 PM
Dc4iNtEgRa's Avatar
This is the TB I purchased... Its alot bigger than the GSR that was on my car, the GSR almost fits in this one...
https://honda-tech.com/zerothread?id=2295820
Old Jul 18, 2008 | 04:51 AM
Dc4iNtEgRa's Avatar
Is it posible to make this OBD-2 throttle body idle correctly without a FITV?
Old Jul 18, 2008 | 08:28 AM
AK_CRX's Avatar
fitv is worthless, I always either block its air passage, or take them off and have the holes welded shut. my IACV keeps idle in check just fine.
monstahtron
Sep 23, 2013 04:18 AM
natebaur
Dec 27, 2009 07:22 PM
92HB_HB
Dec 7, 2006 02:50 AM
lude98SH
Oct 29, 2006 03:17 PM
