SI cluster MPH messed up
Old Jun 25, 2008 | 04:28 PM
SpeedoKing's Avatar
Default SI cluster MPH messed up
ok so i have a 99 civic EX and i jus got a SI cluster i was able to match up the miles and get everything all set up...but when i put it in my car and started it up the MPH needle jumped to 25mph and stayed there! aside from that the cluster works fine the MPH needle does move and seems to give an accurate reading of the mileage aside from the fact that it is 25 over...does anyone know how to fix this problem so it stays at 0?!?!
ooh yeah when i shut the car off the needle drops back down to 0. thanks for any help!
Old Jun 26, 2008 | 03:25 AM
SpeedoKing's Avatar
Default Re: SI cluster MPH messed up (SpeedoKing)
i have been doing some thinking and i am going to install the cluster without the clear plastic shield over it so i can touch the needles and then the car starts and the needle jumps to 25 i was jus going to push the needle back down to 0 and hope that it will stay there. can i do any damage doing this??
Old Jun 26, 2008 | 05:36 AM
BlueIntegraBoy's Avatar
Did you pull the needle off? If so, you didn't place it on in the right spot. Remove the needle, turn the car on to the IGN position, and set the needle on the stop pin.
Old Jun 26, 2008 | 11:51 AM
SpeedoKing's Avatar
Default Re: SI cluster MPH messed up (BlueIntegraBoy)
thats what i did and it worked thanks man but i think that the speedo is not calibrated right b/c it seems to be reading a faster speed than what it should do you by any chance know where i can get that fixed or how to fix it?
Old Jun 26, 2008 | 01:01 PM
Jdmglenn's Avatar
I took the needle off my si cluster also. And to this day its still not calibrated correctly....
Old Jun 26, 2008 | 01:33 PM
SpeedoKing's Avatar
Default Re: SI cluster MPH messed up (Jdmglenn)
ok well i am going to try and get help form a shop that specializes in gauge clusters and repairs. if i find anything out i will let you know....does anyone else have this problem or know how to correct it? any help or pointers will be GREATLY appreciated.
Old Jun 26, 2008 | 04:47 PM
Place the needle slightly below the stop pin. Then pull it up slightly over the pin to let it rest on top of it.
1999jdm
11
Apr 17, 2013 04:22 AM
thaiboiz
13
Sep 3, 2008 09:12 PM
kaboomwoom
Mar 12, 2008 01:06 AM
rcantu
Jul 9, 2006 05:58 PM
JSPECEX
Mar 23, 2003 07:53 PM
