re:b18c5 bad dyno result
still on trial so only allowed 5 posts per day.
did a compression test the day of the dyno an all was ok.
all fuel lines and pump are ok.
could the fpr be set too low.
also check out the air temp and humidity, very hot.
on the second sheet there are two runs, the skinny one is with the silencer in the rear can and the thicker one is without.
look at the difference at about 6k,(almost 25hp)
i still think bad mapping.
the cam gears are set as close to skunk2 spec as i could without a dial gauge,
moved them about a bit too between runs to find best power.
instead of making a new thread, post that ^^^^ up there in your thread you already made, either click <U>Recent Topics</U> under <FONT COLOR="red">Search</FONT> and find your post you already created or click this link to get to it
---> https://honda-tech.com/zerothread?id=2329430
DA TeG 90
Jun 11, 2010 04:17 AM
90accord1
Sep 12, 2002 09:25 AM
