Had timing belt changed and now clutch pedal is sticking
Old Jun 25, 2008 | 01:59 PM
category5 SI's Avatar
Default Had timing belt changed and now clutch pedal is sticking
Had a shop change my timing belt ,water pump, drive belts etc and now my clutch pedal is getting stuck to the floor when going into 1st gear and when it does come back up it's making a noise, it has never done this before could they have messed something up?do you need to fool with the clutch or tranny to do the work that I had done? 1st time pedal got stuck it wouldn't go into gear.
Old Jun 25, 2008 | 02:07 PM
vtecb18c's Avatar
Default Re: Had timing belt changed and now clutch pedal is sticking (category5 SI)
take it back to the place...you got it back with a new problem its their fault
Old Jun 25, 2008 | 02:11 PM
Default Re: Had timing belt changed and now clutch pedal is sticking (vtecb18c)
What could they have done that would affect the clutch?
Old Jun 25, 2008 | 02:13 PM
vtecb18c's Avatar
i have no idea but you didnt do anything so they must of touched something...they might have disconnected the cable to take out something and it might need to be readjusted
Old Jun 25, 2008 | 02:15 PM
I have a 99 si with a hydraulic clutch if that helps any.
Old Jun 25, 2008 | 02:17 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">take it back to the place...you got it back with a new problem its their fault</TD></TR></TABLE> You must be a lawyer at Barnes, Barnes and Cohen. Somebody owes you money. What does a timing belt have to do with a clutch? Let me guess, YOU do not know. I would bet if you had an oil change and your rear brake pads wore out, IT'S THE SHOPS FAULT. LOL
Old Jun 25, 2008 | 02:24 PM
vtecb18c's Avatar
Default Re: Had timing belt changed and now clutch pedal is sticking (DonF)
when a car goes in and has all new stuff replaced and comes up with a sticking clutch, most likely the shop messed with something
Old Jun 25, 2008 | 02:25 PM
Just drove around the block and the pedal isn't sticking but there is a slight grinding when I accelerate, it goes away when I take foot off of gas and doesn't do it in neutral now I'm really lost as to the problem.
Old Jun 25, 2008 | 03:26 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">when a car goes in and has all new stuff replaced and comes up with a sticking clutch, most likely the shop messed with something</TD></TR></TABLE> What part of timing belt and clutch do you not understand? I know, you have 1-800-call a lawyer on speed dial. You do know an oil change has nothing to with brakes, right? A timing belt is on the other side of the motor from the clutch? Or are you one of those DOLTS, I had new tires put on at the shop, and now my car skips, has distributor problems. It's there fault.
I just looked and you are over 16, I am suprised. But you do live at home with mom and dad, correct?
Old Jun 25, 2008 | 03:52 PM
vtecb18c's Avatar
i know what he was saying...im saying that their are shady mechanics out there that do mess with little things so you keep taking it back...i do know that their on diff sides and no i sleep at your house with your mom
Modified by vtecb18c at 5:00 PM 6/25/2008
Old Jun 25, 2008 | 07:45 PM
BlueCrxNC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">i know what he was saying...im saying that their are shady mechanics out there that do mess with little things so you keep taking it back</TD></TR></TABLE>
Seen that. Several years back my mom had a shop do a brake job. Drove off the lot, CEL. I look at it when she gets home and some one had rigged a few of the connectors (MAF, IAT) to be loose/fall off upon driving and set off the CEL. I even quit a job at a local shop because after a year they tried to convience me to lie to people about needs and to rig issues for more returns.
Old Jun 25, 2008 | 07:57 PM
Default Re: Had timing belt changed and now clutch pedal is sticking (BlueCrxNC)
I know the shop quite well and have been bringing my car there for years, I doubt they purposely messed with it. Also noticed when shifting in traffic it had a funny smell.
Old Jun 26, 2008 | 09:17 PM
Black99EM1's Avatar
dont keep driving it man.. just take it back to the shop u dont gotta be a punk about it or nething just be like hey ever since i got it back its been doing this would you mind taking a look at it.. more than likely they want to keep ur return business so they will take a look and probably identify the problem. best of luck and my advice dont keep driving when u have a problem take it back right away before things get worse
PatrickGSR94
Aug 24, 2016 05:07 PM
quiqsilvre
Sep 10, 2008 01:08 PM
seachunk2
Apr 30, 2007 02:30 AM
ITR0952
Sep 23, 2004 02:51 PM
Key
Jun 28, 2002 02:26 PM
