Wheel stud pressing
Old Jun 25, 2008 | 01:58 PM
John 07's Avatar
Default Wheel stud pressing
So i took my R to NBT today to get an estimate of how much it would cost to fix my broken wheel stud and after checking it out on a lift he said no need to take off the wheel stud........?? Now im super confused cuz how do they press out the broken wheel stud and press in the new one if the dust pan is in the way. Do they also hammer out the old stud??? they also told me it would only cost 60 bucks to fix.....
Old Jun 25, 2008 | 02:19 PM
get RIGHT's Avatar
Default Re: Wheel stud pressing (John 07)
It can be pounded out without a press. I just cut the head halfway off and it makes it easier.
Old Jun 25, 2008 | 02:21 PM
migs's Avatar
He will have to remove the wheel. He will probably end up hammering out the old one but if I am not mistaken, he may have to press the hub out of the bearing. If he does this, it is recommended that the wheel bearing be replaced when doing this.
Old Jun 25, 2008 | 02:24 PM
get RIGHT's Avatar
Default Re: Wheel stud pressing (migs)
^^ Good point migs. I was about to edit my post but I'll just follow your's. That being said, pounding it out isnt the correct Honda way of doing it. If you are paying for it you might as well pay a little more and do it right the first time.
Old Jun 25, 2008 | 09:39 PM
John 07's Avatar
So i called the place back and the guy actually said I can get it fixed by the "book" which is to remove the hub it self, but he said he is going to charge much more. I think for now its more economical to fix it the easy way. =/
Old Jun 26, 2008 | 03:07 AM
JOHN WAYNE's Avatar
Default Re: (John 07)
boy...i sure am glad that i wasted 15 minutes of my life trying to help you out in this thread https://honda-tech.com/zerothread?id=2325033
Old Jun 26, 2008 | 09:54 AM
get RIGHT's Avatar
Default Re: (JOHN WAYNE)
^^ I am glad you did. Thats some good info.
Old Jun 26, 2008 | 11:33 AM
BMaDOHC's Avatar
Default Re: (get RIGHT)
just remove the caliper and the little bit of room you have is enough to punch it out with a hammer.
the new one just shave it down a bit on the backside to fit it more easily in between the knuckle and rotor. very easy DIY
kvastek
Honda Civic (2001 - 2005)
Jan 11, 2022 05:29 AM
Unphzd
Dec 17, 2010 01:10 PM
fireslave
Apr 14, 2009 12:27 PM
YoungKadafi
Suspension & Brakes
Mar 10, 2007 05:06 PM
nEoMuGen
Nov 15, 2003 04:17 PM
