Z10 Girdle, YES or NO? ---> LS/VTEC already built and running. Should I add a girdle?
Old Jun 25, 2008 | 12:13 PM
92integraVTECgsr's Avatar
Default Z10 Girdle, YES or NO? ---> LS/VTEC already built and running. Should I add a girdle?
Alright, so I just finished building my LS/VTEC with no girdle. It runs great and put down 187whp @ 8000rpm. All stock OEM Honda Parts.
My tuner said that I should get a girdle since I plan on running the motor past 7k.
He said that he recommends the Z10 girdle because it doesn't require any machine work.
I already have 1000 miles on the motor. It runs great.
The Z10 girdle does not require any machining, just the use of ITR main studs, ITR Windage Tray, ITR Oil Pick Up and ITR Oil Pan.
My main questions are:
1. Has anyone here blown up their LSorB20/VTEC due to not having a girdle?
2. Can I just put the girdle on now and not have to worry about align honing?
3. If I add the girdle now, can that cause any problems?
I do a lot of autox and like to keep the engine in high rpm's.
Old Jun 25, 2008 | 12:33 PM
4g hatch's Avatar
Default Re: Z10 Girdle, YES or NO? ---> LS/VTEC already built and running. Should I add a girdle? (92inte
ive never heard or seen anyone blow a motor up from not having one. the b16's dont have one and there great for autox. it deff would be some peace of mind but i wouldnt do it with the motor already running. you would wanna check the main tunnels to see if it makes them out of round
Old Jun 25, 2008 | 01:00 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
running a girdle will adversely affect your cooling capacity. I wouldn't recommend it.
Old Jun 25, 2008 | 01:25 PM
steveteggy92's Avatar
Can anyone confirm the need for the ITR oil pan/pump/pickup for use with the Z10? never Heard such a thing.
Old Jun 25, 2008 | 01:28 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 &raquo;</TD></TR><TR><TD CLASS="quote">running a girdle will adversely affect your cooling capacity. I wouldn't recommend it.</TD></TR></TABLE>
Im pretty sure youre thinking of a block guard.
Old Jun 25, 2008 | 01:39 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">
2. Can I just put the girdle on now and not have to worry about align honing?</TD></TR></TABLE>
I don't really have a lot of experience with that gridle but if your motor is already running good, why mess with it now. Getting the right torque on the mains in car is not a fun task.
Old Jun 25, 2008 | 01:50 PM
Default Re: (steveteggy92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveteggy92 &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone confirm the need for the ITR oil pan/pump/pickup for use with the Z10? never Heard such a thing.</TD></TR></TABLE>
it says it right on their website.
Old Jun 25, 2008 | 02:12 PM
2LEM1's Avatar
I like to party
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
Im pretty sure youre thinking of a block guard. </TD></TR></TABLE>
Ahh, you are correct. Reading... gets me every time.
Old Jun 25, 2008 | 05:02 PM
so whats your opinion on my questions?
Old Jun 25, 2008 | 07:29 PM
prodragEG's Avatar
only the grs/typeR(the same) baffle plate and pickup screen will clear the girdle and IF you use the ls oil pan, the pickup screen will hit the bottom of the pan cause the gsr/typeR pickup sit lower. Thats why you use the gsr oil pan.
Old Jun 26, 2008 | 10:15 AM
ExospeedAMcrx's Avatar
Girdles over rated.
700+hp turbo cars with 10,500K RPM range, with no girdles. Alot are running it this way. If those setups are beating it up at that HP level. I'm sure a 200hp all motor isnt going to need it.
Old Jun 27, 2008 | 12:00 PM
quicksilver1689's Avatar
i ♥ snails
yeah i feel the same as exospeed they cant hurt unless the distort the mains but alot has been done without them. I would focus somewhere else on tbe build.
Old Jun 27, 2008 | 12:22 PM
acydphryck's Avatar
if the motor was meant to have a girdle, it would have come stock with one straight from the factory.
*EDIT* ok ok...i'll cool it off just for today
Modified by acydphryck at 1:39 PM 6/27/2008
Modified by acydphryck at 1:49 PM 6/27/2008
Modified by acydphryck at 1:54 PM 6/27/2008
Modified by acydphryck at 1:55 PM 6/27/2008
Old Jun 27, 2008 | 12:49 PM
pinoyrnr's Avatar
wow pants you should be easy on the newbees!!!!! lmao!!
Old Jun 27, 2008 | 05:32 PM
narfdanarf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck &raquo;</TD></TR><TR><TD CLASS="quote">if the motor was meant to have a girdle, it would have come stock with one straight from the factory.
yeah man if the motor was meant to have big cams, high compression, and rev to 10k it would have came that way from the factory.
Old Jun 27, 2008 | 08:13 PM
killerpenguin21's Avatar
the z10 does in fact need machining, you would be stupid to not align hone/bore it after you installed it because it affects the shape of the mains. i run a gsr girdle, and had it checked for roundness and i liked out since it was fine and didnt need a hone.
Old Jun 28, 2008 | 12:29 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narfdanarf &raquo;</TD></TR><TR><TD CLASS="quote">
yeah man if the motor was meant to have big cams, high compression, and rev to 10k it would have came that way from the factory. </TD></TR></TABLE>
i was being sarcastic jackson...if you took my comment seriously, you need to get laid
Old Jun 28, 2008 | 12:44 AM
MOE@Hyper16Valve's Avatar
HA ha post those dyno sheets to let everyone know you mean BUSINESS...
Old Jun 28, 2008 | 12:47 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOE@Hyper16Valve &raquo;</TD></TR><TR><TD CLASS="quote">HA ha post those dyno sheets to let everyone know you mean BUSINESS...</TD></TR></TABLE>
i would but 2LEM1 doesn't think it exists and i'm just LOL!!!
Old Jun 28, 2008 | 12:49 AM
Your funny BUT i got a k20 @@@ mi casa now LOL now...
Old Jun 28, 2008 | 12:50 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOE@Hyper16Valve &raquo;</TD></TR><TR><TD CLASS="quote">Your funny BUT i got a k20 @@@ mi casa now LOL now...</TD></TR></TABLE>
those things come stock with a girdle right??? OH SNAPS!!!
Old Jun 28, 2008 | 05:50 AM
DARKB20's Avatar
JOE'S DYNO
Old Jun 28, 2008 | 12:27 PM
Brick Top's Avatar
^^ and there it is again.
Exospeed said it right. over rated.
wreckeddc4
44
Oct 10, 2011 09:49 PM
carlossolorzano
Aug 5, 2010 09:43 AM
NA_DA
10
Feb 27, 2008 09:58 AM
JDMB20TDA
Jan 21, 2007 08:15 PM
ek4ferrio
14
Oct 8, 2006 09:50 AM
