How can I get water out of my tail light?
Apparently the factory glue holding my light together is beginning to go because my light keeps filling with water. I have drained it a few times and put it back on but now I actually have day off to fix it. My main concern is that the water has gotten into the reflector, I cant figure out how it got in there. I know you can bake the tail lights apart, but I'm not really comfortable doing that as this is my daily. I may just have to man up and do it though. Anyone have any suggestions? The inside of the whole lens is hazy now too, any way to clean that without taking it apart? If taking it apart seems to be my only option, some tips on doing that would be super, thanks
If you have an air compressor.. take the air hose and blow it out..
Try using silicone to reseal it..
As far as the hazyness try to stuff a shop rag in there and using something to poke/move the rag around
I only need the passenger side outer, I'm letting some paper towels sit in it but they arent helping much
u have a PM
u have a PM
Pop it in the over for 10 mins. It should pull right apart. Dry it out, then put some silicone to re seal it. My depos did it and they dont leak anymore
