changed head gasket now the car wont start.
Old Jun 24, 2008 | 11:14 PM
the king.'s Avatar
Default changed head gasket now the car wont start.
i just finished assemblying the motor after i changed the head gasket and it wont start. it goes chug chug chug pop pop. idk what to do please help me!!
also i checked the compression and its good on all four cylinders.
oh i have an f22a1.
Old Jun 25, 2008 | 06:08 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: changed head gasket now the car wont start. (the king.)
have you double checked over everything in the timing belt area to make sure you aligned everything correctly on assembly?
Old Jun 25, 2008 | 06:09 AM
SpazMan's Avatar
Default Re: changed head gasket now the car wont start. (TouringAccord)
Is the distributor aligned correctly? Plug wires?
Ari
Old Jun 25, 2008 | 09:43 AM
the king.'s Avatar
Default Re: changed head gasket now the car wont start. (SpazMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpazMan &raquo;</TD></TR><TR><TD CLASS="quote">Is the distributor aligned correctly? Plug wires?
Ari</TD></TR></TABLE>
what do u mean by that, the distributor pin is in the cam, is there anything else?
also timing looks right
Old Jun 25, 2008 | 01:53 PM
mbogosia's Avatar
The distributor needs to align correctly when you install it. It should slide right in so if you had trouble getting it in there I would take it back out and check it. This will cause the car not to start.
Old Jun 25, 2008 | 02:04 PM
91h22cb7lx's Avatar
Default Re: changed head gasket now the car wont start. (mbogosia)
did you miss the ground by the water outlet, the one that grounds the ecu
Old Jun 25, 2008 | 02:17 PM
ronqqq's Avatar
Default Re: changed head gasket now the car wont start. (91h22cb7lx)
try changing your plugs wire 180 on cap.
Old Jun 25, 2008 | 02:37 PM
technine's Avatar
Did you put your timing belt on correctly? Do you have your spark plug wires in correct order on the distributor (common problem some people have)?
Did you make sure all electrical connections are good and everything is grounded properly?
Old Jun 26, 2008 | 10:57 AM
the king.'s Avatar
Default Re: changed head gasket now the car wont start. (technine)
if the timing belt was not put on correctly wouldn't the car have no compression on at least one cylinder??? we have good compression on all 4 so im assuming there is nothing wrong with the timing belt itself but more ignition or fuel
please advise
Old Jun 26, 2008 | 11:20 AM
GhostAccord's Avatar
Have you checked the spark plugs for spark and the injectors for fuel?
Old Jun 26, 2008 | 05:45 PM
technine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the king. &raquo;</TD></TR><TR><TD CLASS="quote">if the timing belt was not put on correctly wouldn't the car have no compression on at least one cylinder??? we have good compression on all 4 so im assuming there is nothing wrong with the timing belt itself but more ignition or fuel
please advise</TD></TR></TABLE>
Well, you did say it won't start. Did you check any of the things I asked? Spark plug order at least?
Old Jun 26, 2008 | 11:02 PM
the king.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">
Well, you did say it won't start. Did you check any of the things I asked? Spark plug order at least?</TD></TR></TABLE>
yeah i did and i checked the firing order and now it starts
Old Jun 27, 2008 | 09:04 AM
professorman's Avatar
Cool! Did you find what was causing it?
Old Jun 27, 2008 | 10:32 AM
technine's Avatar
yeah i did and i checked the firing order and now it starts</TD></TR></TABLE>
You're welcome??
Old Jun 27, 2008 | 11:36 AM
the king.'s Avatar
You're welcome??</TD></TR></TABLE>
thank you i greatly apreciate your help, you saved me from selling the car.
crvglenn
Honda CR-V & Element
Sep 11, 2017 03:42 PM
egtony
10
Sep 4, 2009 01:44 PM
lil_mowgli
Apr 4, 2009 06:16 PM
2wheelhunter
23
Jun 30, 2008 08:23 PM
drifterX420
Jul 11, 2007 12:47 PM
