My SOHC Ninja Project ;)
Old Jun 24, 2008 | 10:02 PM
d16drag-on's Avatar
Default My SOHC Ninja Project ;)
Hi guys,
I've been lurking around here for a while now and never really had a chance to introduce myself. My name is Edo, I'm 27 years young and this is my Honda, purchased bone stock in '06 with 64,000 original kms.
Under The Hood:
y8block, z6head, secured with arp head studs, powered by .42/.48 ar t3 @ 10psi, port & polished oil pump, denso dsm 450cc injectors with resistor box & custom wiring with 3 sequential system disengage/kill switches, ngk spark plugs, ngk wires, walbro 255lph fuel pump, b&m fpr @ 42psi, g-sport fuel rail, mishimoto intercooler, fal slim rad fan, mitsu rs type bov, xs-power twist-ram turbo race manifold (2.9mm thick piping, 50mm primaries, stainless steel construction, tig welds, anti-warp flange supports) 38mm vband wastegate, 3" downpipe & 2.5" full exhaust pipe with resonator by ovrbst, apexi n1 exhaust, rebuilt axles, stage 3 pressure plate with 6puck sprung disc and oem flywheel
Brains:
obd1 p28 ecu, uberdata 1.66, street tuned on stock map sensor
approx 220~230whp @ 10psi, 12afr
2.5bar motorola map sensor, street tuned with ngk wideband O2
14psi ~270whp @ 7500rpm, 11.5afr
(safe street tune, experimental use)
Stiff Stuff:
omni power sport coilover system @ 12/10kg spring rate
blox 22mm sway bar
Stoppers:
drilled/slotted brembo blanks
ceramic brake pads
Rollers:
17" Motegi SP5, 205/40/17 Falken Ziex 912
Outside:
type-r (pu) front lip, hc (chargespeed style) rear lip, rear visor,
door visors, eg side markers, custom headlight conversion,
isuzu tail lights, domani badging, prototype torpedo grill
Inside:
custom race seats, custom mugen harness, sparco rails,
autometer boost gauge, r1 pedals, custom domani cluster
Fluids & Misc:
eneos japan motor oil, redline transmission fluid,
hamp oil filter, blox magnetic drain plugs, mugen thermo switch
*Special thanks to my mom & dad (yes, they helped too )
my bro, crdjan, overboost, honda-tech, clubEL, honda tuning magazine
and king motorsport for all the help and support.
I ♥ my Honda
*Plans for '09 include rear disc swap, cf hood, g16 vitara pistons, eagle rods, russell brake lines, new paint
Modified by d16drag-on at 1:08 AM 6/25/2008
Modified by d16drag-on at 3:43 AM 6/27/2008
Old Jun 24, 2008 | 10:27 PM
JDM_JNKY's Avatar
hahaaaa gangster sohc el!
Old Jun 24, 2008 | 10:46 PM
phatboycrxhf's Avatar
Default Re: (JDM_JNKY)
clean as hell dude ,great job ,how much did the manifold run you ?
Old Jun 24, 2008 | 11:08 PM
d16drag-on's Avatar
Default Re: (phatboycrxhf)
$200 for mani, +24 of bud for machining the flanges, 1 nfs game for my bro lolz (he welded in the flange supports so mani doesn't flex or warp and supports the weight of turbo+dp)
Old Jun 27, 2008 | 04:02 AM
d16drag-on's Avatar
Default Re: (d16drag-on)
the 1st 2 images show the manifold when i got it. the next 2 images show what was done to it after. sorry.. kinda dark, i hate my camera i'll take better pix soon.
oh... and look what i found in the mail today
Old Jun 27, 2008 | 10:18 PM
nice keep up the good work ,you got the hook up for B series manifolds too ?
Old Jun 28, 2008 | 03:13 PM
d16drag-on's Avatar
thanx bud! i just sold 2 bseries manifolds and only got a d left, but if you need a specific design, let me know.
Old Jun 28, 2008 | 05:21 PM
EcivicG's Avatar
what is that??
sorry if its a dumb question.
looks like a weird accord.
Old Jun 28, 2008 | 07:32 PM
Tippyman's Avatar
Default Re: (EcivicG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EcivicG &raquo;</TD></TR><TR><TD CLASS="quote">what is that??
looks like a weird accord.</TD></TR></TABLE>
Outside:
Old Jun 29, 2008 | 02:08 AM
d16drag-on's Avatar
lol no worries. It does look like an Accord, only smaller. It is the 1st generation Acura 1.6EL; rebadged version of the Japanese marketed Honda Domani. It's pretty much a Civic 4door chassis (96-00 Ex) with an upgraded interior and front/rear end.
Modified by d16drag-on at 7:06 AM 6/29/2008
Old Jun 29, 2008 | 01:15 PM
EcivicG's Avatar
well it looks good
never seen one before. different.
Old Jun 29, 2008 | 01:24 PM
Brice.Hayden's Avatar
rims look like **** but car overall is pretty cool.
Old Jun 30, 2008 | 12:34 AM
d16drag-on's Avatar
lol well thanx! I've been thinking about some low offsets, just haven't found anything I really like. Suggestions welcome!
Freemananana
Jul 18, 2014 04:34 PM
91DA-C
Jun 7, 2010 01:04 PM
88sleeperx
Aug 21, 2006 08:33 AM
eg686
Jul 7, 2003 06:38 PM
