Extra bolts after reassembling my B16 head!
Old Jun 24, 2008 | 06:36 PM
SolAssassin's Avatar
Default Extra bolts after reassembling my B16 head!
As stupid as this sounds, I have extra bolts after assembling my head!
The 2 smaller screws look like they MIGHT fit the inner timing cover? The other 2 I'm not sure about. They are NOT for the plug wire cover. Those 4 bolts are already installed and are longer. I can't find these bolts anywhere on these 2 diagrams either! Do these look familiar to anyone?
Old Jun 24, 2008 | 08:28 PM
fourthgenhatchB17's Avatar
Default Re: Extra bolts after reassembling my B16 head! (SolAssassin)
Can u get a clearer picture? The 2 on the right definitely look like #20 to me.
Also, by chance did u receive the head and its parts already disassembled?
Edit: negative on the clearer picture, my screen at work sucked..at home i can see them perfectly, lol.
Modified by fourthgenhatchB17 at 12:48 AM 6/25/2008
Old Jun 24, 2008 | 08:52 PM
hotrod99's Avatar
Default Re: Extra bolts after reassembling my B16 head! (fourthgenhatchB17)
looks like bolts for the valve cover
Old Jun 24, 2008 | 09:33 PM
HEAD's Avatar
Default Re: Extra bolts after reassembling my B16 head! (hotrod99)
numbers 16,17-19,20...valve cover/cam cap
Old Jun 24, 2008 | 11:51 PM
Default Re: Extra bolts after reassembling my B16 head! (HEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD &raquo;</TD></TR><TR><TD CLASS="quote">numbers 16,17-19,20...valve cover/cam cap </TD></TR></TABLE>
#19 is a head bolt, lol.
Now that i can see the picture clearer, the 2 on the left dont even look like they're from a B16 head. I dont recall ever seeing those. They look like they may be from a sohc.
Old Jun 25, 2008 | 04:33 AM
HEAD's Avatar
lol..19 is a head bolt!
the ones to the left are from the cam cap..and don't actually have to be removed for disassembly.
Old Jun 25, 2008 | 05:30 AM
everything on the cam caps have been assembled. yes, i did receive the head unassembled from a friend. sorry for the crappy pic, i took it with my phone.
both pairs of bolts are threaded on each end. i tried the 2 smaller bolts in the holes where the inner timing cover goes (though i'm not sure i'll even be able to use it because the lower lip doesn't line up with the b20 block) and they fit, but i'm not positive that they go there. the 2 longer bolts do indeed look like they should be for the valve cover, but i already installed the 4 bolts that go there. those bolts have a shorter base and a longer head. maybe you guys are right and these don't belong to this head
Old Jun 25, 2008 | 07:42 AM
dyingwish's Avatar
There are more than 4 bolts that hold on the valve cover, in fact there are 8. 4 on the outer corners, and 4 inner ones that are integrated as cap cap and cover bolts.
Old Jun 25, 2008 | 08:51 AM
Default Re: Extra bolts after reassembling my B16 head! (dyingwish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyingwish &raquo;</TD></TR><TR><TD CLASS="quote">There are more than 4 bolts that hold on the valve cover, in fact there are 8. 4 on the outer corners, and 4 inner ones that are integrated as cap cap and cover bolts. </TD></TR></TABLE>
yeah but those are already on there. and they don't look like those bolts
Old Jun 25, 2008 | 10:55 AM
It also looks like the 2 on the left are upside down. Look at which side u can fit a socket on. Im tellin ya, i dont think they're from this head, lol.
yeegsr
Sep 23, 2004 03:32 PM
Type_Rydah
Dec 23, 2003 06:20 AM
VXpride
Jul 31, 2003 08:53 AM
MrSmith
Jul 21, 2001 02:33 AM
