wire harness setup for honda del sol(need instructions or help)
Old Jun 24, 2008 | 05:37 PM
Chim64's Avatar
Default wire harness setup for honda del sol(need instructions or help)
This is the wire harness i have to replace anyone have tips or directions on how to replace this?Part is called WIRE HARNESS, RR. part number 32108-SR2-A13. Also i will pay someone to do it for me. I live in Indiana pa. I
I have the part.
Old Jun 24, 2008 | 11:26 PM
Chim64's Avatar
Default Re: wire harness setup for honda del sol(need instructions or help) (Chim64)
anyone?
Old Jun 25, 2008 | 09:48 AM
Chim64's Avatar
bump
Old Jun 25, 2008 | 11:16 AM
slvrcvc93's Avatar
its actually a section of wires that clips on from the lower left kick panel all the way to the rear you just have to take out the seats and maybe the carpet you might be able just to pull it down. It goes to the fuel pump, after that it goes directly to the rear of the car where there another clip on section that powers the taillights you will have to take off any plastic panels covering it when you get right next to the taillight should unclip easily then your done.
Old Jun 25, 2008 | 11:23 AM
fortymcpants's Avatar
I remember that being a pain in the *** in the civic because it tied off to a lot of different things, I thought it was more than the fuel pump.
Old Jun 25, 2008 | 12:01 PM
Nbboy7's Avatar
I would do it but how far are from NJ? I had the same problem in my sol I drooped a penny in the lighter and melted all the wires together
Old Jun 25, 2008 | 01:30 PM
slvrcvc93's Avatar
Default Re: (Nbboy7)
it is time consuming but it definitely isn't hard to do if your close to NJ man i can go help I live near woodbridge so if your within 60 min more or less ill help you like i said easy fix all you have to do is pay for my gas there and back.
Old Jun 25, 2008 | 03:36 PM
Chim64's Avatar
Default Re: (slvrcvc93)
i am a hr from pittsburgh.... which is prob 4 to 5 hrs from nj.
Old Jun 26, 2008 | 06:24 AM
Chim64's Avatar
Old Jun 26, 2008 | 08:26 AM
slvrcvc93's Avatar
thats a lil 2 far buddy but like i said try it it is very easy
Old Jun 26, 2008 | 07:21 PM
Chim64's Avatar
i did a temp fix. I replaced all the shorted out wires. and then crimped the new wires in. Taped each wire individually then tapped a clean look. After that everything was fine. no shortage problem. I have a full interior wire harness setup for sale. I might install the piece in my car that i temp fixed but otehr than that its fully.
Old Jun 27, 2008 | 04:25 AM
Chim64's Avatar
Default Re: (Chim64)
might replace the harness tonight. The temp fix is holding up though.
Old Jun 27, 2008 | 04:36 AM
denraweb's Avatar
well since you used connectors and it's holding up, if you decide not to change out the whole harness, I would suggest soldering the wires and using some shrink tubing to seal everything...alot better than connectors...
Old Jun 28, 2008 | 06:50 PM
Chim64's Avatar
Default Re: (denraweb)
i started doing the replacement and noticed i have to replace the dash also..... so yah i need help extreamly idk where the dash harness stuff is run and how to get to it. I already removed the dash but idk what eles to remove to get to the old harness setup.
Old Jun 29, 2008 | 12:49 PM
Chim64's Avatar
I need to know how to get that off....
Old Jun 29, 2008 | 12:53 PM
Chim64's Avatar
help!!..bump...
Old Jun 29, 2008 | 01:45 PM
Chim64's Avatar
ANYONE!?!?!?! HELP?!?!
Old Jun 29, 2008 | 02:54 PM
Chim64's Avatar
BUMP/./...HELP...
Old Jun 29, 2008 | 07:06 PM
ShortyzKustomz's Avatar
Wow Indiana Pa...I worked there while I was going to Wyotech... Many nights partying at IUP, Small world!
Old Jun 29, 2008 | 09:53 PM
sorullo's Avatar
go to this web site.. they can help you out.. or just email them ..!!!
http://www.knology.net/~jediklc/
Old Jun 30, 2008 | 06:53 AM
Chim64's Avatar
Default Re: wire harness setup for honda del sol(need instructions or help) (sorullo)
yah there is nothing on there that tells me how to remove that piece. i emailed him but he didn't respond.
Old Jun 30, 2008 | 08:20 AM
Bakeoff's Avatar
There is a nut on teh firewall you ahve to take off along with the heater core hoses.
Old Jun 30, 2008 | 04:21 PM
Chim64's Avatar
Default Re: (Bakeoff)
wish i knew what nut haha..
Old Jul 1, 2008 | 04:56 AM
Chim64's Avatar
car should be done today. wish me luck
spoolinvtec54
Engine Management and Tuning
11
Feb 13, 2020 09:45 AM
soNNy638
Audio / Security / Video
Mar 28, 2010 06:55 AM
hitekper4mance
Oct 9, 2007 08:21 AM
