Possible ISB?
Old Jun 24, 2008 | 05:28 PM
antivic's Avatar
Default Possible ISB?
recently purchased a 01 ITR trans, when i went to inspect the transmission i spun the input shaft and it seemed to make some sorta clicking noise. The noise only comes on the initial tug and nothing there on out. Is this normal? or am i looking at possible issues? any input is appreciated...thanks!
Old Jun 24, 2008 | 05:32 PM
vtecb18c's Avatar
Default Re: Possible ISB? (antivic)
could be the lsd making noise
Old Jun 24, 2008 | 05:56 PM
antivic's Avatar
Default Re: Possible ISB? (vtecb18c)
would this be normal? or should i look into this more?
Old Jun 24, 2008 | 08:33 PM
fourthgenhatchB17's Avatar
Wiggle the input shaft up/down/side to side. Does it move independently from the trans housing? Thats usually my initial check and about as much as u can do without opening up the case. Rotating the shaft will produce some noise.
Old Jun 25, 2008 | 03:42 AM
antivic's Avatar
Default Re: Possible ISB? (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Wiggle the input shaft up/down/side to side. Does it move independently from the trans housing? Thats usually my initial check and about as much as u can do without opening up the case. Rotating the shaft will produce some noise.</TD></TR></TABLE>
okay cool, other than that click everything else was sturdy...i can only hope for the best, haha.
civilsantana
Transmission & Drivetrain
Aug 5, 2016 04:42 AM
crxjarred
Sep 6, 2008 02:24 PM
ITR-EKcoupe
Aug 13, 2008 09:46 PM
isacivic
May 31, 2008 01:17 PM
njracer
Apr 1, 2008 02:28 AM
