need help adjusting stiffness in my clutch
Old Jun 24, 2008 | 01:58 PM
allshownogo's Avatar
Default need help adjusting stiffness in my clutch
how do i make my clutch stiffer? its hydraulic.
Old Jun 24, 2008 | 02:14 PM
1CaMw0nDeR's Avatar
Default Re: need help adjusting stiffness in my clutch (allshownogo)
Bleed the system until theres 0% air bubbles coming out, than bleed it one more time...
You can also adjust your clutch pedal up under where ur pedal is at, theres a nut on a bolt that holds ur clutch pedal from going to far forward and backward, adjusting that sometimes makes it seem a bit stiffer...
Old Jun 24, 2008 | 04:06 PM
ej2man's Avatar
possibly a stage 2 pressure plate. correct me if im wrong
Old Jun 24, 2008 | 04:27 PM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshownogo &raquo;</TD></TR><TR><TD CLASS="quote">how do i make my clutch stiffer? its hydraulic.</TD></TR></TABLE>
Stiffer like it used to be? Stiffer like it should be? Dun get it.
If it isn't as stiff/hard LOL as it sould be a bleeding is in order. Next I would question the slave cylinder and next the clutch master cylinder.
Orignial clutch?
Old Jun 25, 2008 | 12:06 AM
obuhmyuh's Avatar
Default Re: need help adjusting stiffness in my clutch (mcvtec)
upgrade your clutch/pressure plate.
Stonage07
Mar 6, 2017 11:48 AM
crazyguy
Jun 8, 2007 01:16 PM
LSEGHATCH
May 2, 2006 06:18 AM
B-SerioUs EGg
Dec 22, 2005 03:42 PM
Jeffrey9
Nov 29, 2005 02:57 PM
