A/C in a 2000 civic? which ac mount do i need?
So i have a 2000 civic DX and id like to keep my AC is there a bracket i can use to keep the civic compressor with my gsr swap? tried civic Si bracket and thats a no go.
Ive heard the crv bracket?
Any help is greatly appreciated.
I have been asking the same question and I believe the CRV or Del Sol A/C brackets will both work. That is if they both come off either a B20 or B16.
well i ordered a civic si (1999) which is the same part number as a del sol vtec, and that does not work, does not bolt on the compressor that is.
So anyone else? does hasport make something?
ITS TOO HOT!
thanks guys... ill keep searching.
ITS TOO HOT!
I just bought a 99-00 CRV bracket for my gsr swap. Haven't got the motor in yet, but I'm 99% sure it's right, and here's why:
1. I have a 99 CRV. I looked under the hood. The AC compressor looks identical to my d16 compressor. The bolt holes are in the same locations, and the hoses are clocked the same directions. It looks totally different from my gsr AC compressor.
2. The CRV has a B series engine, and apparently the same d series AC compressor that's in my 2000 d16y8.
3. The CRV bracket bolts right up to my gsr as shown in the right side of this picture:
4. Therefore, we can deduce that the CRV bracket is the correct bracket to use when installing a d series AC compressor on a B series engine. I can't verify for another week or 2 when I actually get my swap installed, but all indications say that's correct.
Ok fellas good news the crv ac bracket works like a charm, the only thing is make sure u have the belt on if ur gunna use the lower mount cause its almost impossible to put the belt on afterwards since the mount goes through the belt.
Some more good news the type r aluminum mount works as well but the holes are there but not threaded. Ull have to tap them and BAM ready to go!
Hope yall enjoy ur AC like I will
hey i know this thread has been dead a long time ago but im doing a b20 swap om my 98 civic and the b20 is complete with the a/c bracket will this work using my d16 a/c compressor
GapxGuy
Feb 20, 2003 04:40 PM
CivicEx95
Apr 25, 2002 01:04 PM
