stock mounts for b16 ef swap
Old Jun 23, 2008 | 02:50 PM
axionm1k's Avatar
Default stock mounts for b16 ef swap
I have a mount kit that is for a b series swap for a ef 88-91 civic/crx but i only have the transmission frnt and side mount i need the mount for the engine and rear trans i wanted to know if there was stock mounts that i could use for the engine and rear trans for a b16 cable in a ef
Old Jun 23, 2008 | 03:36 PM
IndySporty's Avatar
Default Re: stock mounts for b16 ef swap (axionm1k)
That happened to me once. I used the stock EF rear mount on the crossmember, and used the dog bone mount from the DA and drilled a new hole in it to bolt to the crossmember mount. It looked wierd and was a ***** to install/uninstall, but it saved me from getting a new mount kit and held together until the car was retired.
Old Jun 23, 2008 | 05:06 PM
Crx Jimmy's Avatar
Many of the old mount kits only used 2 new mounts. you can unbolt the stock rear mount and move it over to the other set of holes on the crossmember. You can also use a 90-93 integra rear mount. I have one of those old steel mount kits as well and am using the integra mount filled with window-weld. The 90-93 integra mount is much stiffer and thicker than the stock d series one.
JustEFit
Jan 1, 2013 10:21 PM
Banner
Jul 30, 2010 04:39 AM
axionm1k
Jul 4, 2008 11:17 AM
illestrolla247
13
May 24, 2005 10:19 AM
swaplighter
Mar 2, 2003 03:21 PM
