Oil Pan
Old Jun 23, 2008 | 11:07 AM
Morenci's Avatar
Default Oil Pan
I have 94 Del Sol. The oil pan need to be resealed. Are there any benefit to just replacing it instead of resealing it?
Old Jun 23, 2008 | 11:14 AM
northkai3's Avatar
Default Re: Oil Pan (Morenci)
not unles your drain plug is stripped or your pan is dented. if not then just reseal it.
Old Jun 23, 2008 | 11:36 AM
instructor74's Avatar
Default Re: Oil Pan (northkai3)
just buy the oem gasket and replace it. You have to take off the trans braces to get the trans access cover out of the way and be careful with the pan bolts the are easy to cross thread and very small dia and do not take much to break or strip.Also only use a small amount of sealent around the hump on the gasket you don't need any anywhere else
Old Jun 23, 2008 | 11:52 AM
Morenci's Avatar
Default Re: Oil Pan (instructor74)
thankx
Curlybandit
Engine Machining & Assembly
Aug 13, 2018 12:18 PM
deconstruct
Jun 18, 2004 01:00 PM
hondaracing1
11
Mar 18, 2004 04:01 PM
MR. ARIZONA
Sep 3, 2003 05:04 PM
