Honda S2000 Honda S2000
To which color wire of the O2 sensor do I attach the rich/lean gauge?
Old Jun 23, 2008 | 03:52 AM
maddcrx's Avatar
Default To which color wire of the O2 sensor do I attach the rich/lean gauge?
Hi, I hava a 2001 S2000 and wanted to put a rich/lean gauge!!
I wanted to know to which color wire of the oxygen sensor do I need to attach the gauge to!! Any help?? Thanks!!
Old Jun 23, 2008 | 05:05 AM
chimmike's Avatar
Default Re: To which color wire of the O2 sensor do I attach the rich/lean gauge? (maddcrx)
don't waste your time on the rice gauge.
IIRC the o2 sensors on this car are narrowband.
....correct me if I'm wrong.
Old Jun 23, 2008 | 10:56 AM
White Smoke's Avatar
i my honda
Global Mod
C16 is the Primary O2 Sensor Wire
You stock sensor is narrow band so it is only accurate from about 14.4-15.1. The gauge should not be used for tuning! But it can give you some insight as to what your ECU is doing to correct the A/F ratio. The generally consensus is that these gauges are just for show. If you are really trying to tune your car, look into a wideband.
You should be using shielded wire to make this connection.
Old Jun 23, 2008 | 01:43 PM
HondaKyle's Avatar
Default FV-QR
its an air fuel gauge... not a rich lean gauge... what about stoich?
You know that gauge is next to pointless?
Old Jun 23, 2008 | 07:15 PM
iam7head's Avatar
Default Re: FV-QR (HondaKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">its an air fuel gauge... not a rich lean gauge... what about stoich?
You know that gauge is next to pointless?</TD></TR></TABLE>
well, it's not the gauge that is useless, it's the narrow band sensor that make the whole thing a light show.
the op got a point, it only shoot from lean to rich and that's about it
Old Jun 26, 2008 | 03:55 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: FV-QR (iam7head)
the need for this gauge presents itself because??
maddcrx
Jun 23, 2008 10:57 PM
maddcrx
Honda Civic (2001 - 2005)
Jun 23, 2008 07:48 AM
DohctorVtec
Oct 19, 2005 05:44 PM
photonjedi808
25
Apr 17, 2003 12:08 AM
civictypenos
Oct 10, 2002 07:40 AM
