knock sensor
Old Jun 22, 2008 | 11:08 PM
cmgibby's Avatar
Default knock sensor
D16Y5 1.6
throw a knock sensor wire malf code, using a OBD2 code reader.......
trying to find out where this sensor is located on the engine, what it does. looked in haynes yet is mass produced general crap! can anyone help!?
Old Jun 23, 2008 | 01:59 AM
Davus's Avatar
Hm, on my Y8 it was right below cylinder 2 on the intake manifold. Big socket required to remove it, about a 27mm or so. Cylinder 2 as in looking from driver's seat, that is. Second farthest from belts.
Best of luck. Should be same on Y5 I'd guess. (Different on Y7 of course, since they lack a knock sensor. :-))
Old Jun 27, 2008 | 12:17 AM
cmgibby's Avatar
Default Re: (Davus)
true! i found it however it is a big "plug" in the motor therefore the sensor isnt there. since the threads to plug are diff size than the sensor i have to fins some sort of adapter, its more or less a pain the butt
anyone know where i can get that from
SpoonFedEj8
Dec 23, 2008 03:11 PM
odyssey2001
Acura TL, RL & ZDX
Dec 31, 2005 08:24 AM
CM-R
Mar 29, 2002 12:34 AM
