very low idle at start up, any ideas???
Old Jun 22, 2008 | 07:57 PM
oneprelude's Avatar
Default very low idle at start up, any ideas???
At start up, engine idles like around 100 rpm. When i step on the gas pedal, it goes back to normal. What might it be?? Thanks for the help
Old Jun 28, 2008 | 11:44 PM
h23fukvtec's Avatar
Default Re: very low idle at start up, any ideas??? (oneprelude)
spark plugs most likely
Old Jun 29, 2008 | 05:55 AM
vlang29's Avatar
Fast Idle Thermo Valve
Old Jun 29, 2008 | 06:01 AM
Acidcrakker's Avatar
Default Re: very low idle at start up, any ideas??? (vlang29)
So the engine Idles @ 100 rpms?
You do know that the motor will not idle under 400, cause it wont stay on!
Old Jun 29, 2008 | 08:11 AM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">Fast Idle Thermo Valve</TD></TR></TABLE>
especially if it's only at a cold startup. if the car is warmed up and you shut it off and start it up do yo u have the same issues? if not then check the fitv
Old Jun 30, 2008 | 06:21 AM
vlang29's Avatar
Default Re: very low idle at start up, any ideas??? (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">So the engine Idles @ 100 rpms?
You do know that the motor will not idle under 400, cause it wont stay on!</TD></TR></TABLE>
The graduation marks between the 0-1k are NOT even graduations. if the idle is below about 4-500, the tach will register ZERO.. and i've had my engine keep stumbling along as low as 250
Old Jun 30, 2008 | 06:22 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">and i've had my engine keep stumbling along as low as 250 </TD></TR></TABLE>
indicated by tach on my vafc, not the dash tach
hai_tech
19
Mar 20, 2007 07:26 PM
Freshsho
May 25, 2005 12:49 PM
jdmstreethatch
13
Apr 5, 2004 11:09 AM
sleepyhamsterlx
17
Dec 15, 2003 02:55 PM
Smith Wise
Sep 17, 2003 01:32 PM
