Tranny Rattle?
Old Jun 22, 2008 | 06:53 PM
goodtrouble's Avatar
Default Tranny Rattle?
As the title states, I'm having a rattling issue in my tranny and have no idea what could be causing it. The rattle is there when I start the car, but it goes away after I depress the clutch. Is my tranny going or is it my clutch? Btw, the tranny shifts fine with no grinds. Also, I have a rattle at about 3k rpm, anything above that it goes away. I've got it narrowed down to the engine bay, but could the tranny be causing this rattle as well?? Any insight would be great.
Thanks in advance
Old Jun 22, 2008 | 09:27 PM
ls19integra95's Avatar
Default Re: Tranny Rattle? (goodtrouble)
you sure its your tranny and not like a heatshield hitting the exhaust? my buddy had exact problem and thought his trans was going just because it sounded like his trans when it was actually just a heat shield was rusted and rattling
Old Jun 22, 2008 | 09:29 PM
Rediness_code's Avatar
Default Re: Tranny Rattle? (ls19integra95)
This might help.
https://honda-tech.com/zerothread/1999434
Old Jun 23, 2008 | 01:29 PM
Default Re: Tranny Rattle? (Rediness_code)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">you sure its your tranny and not like a heatshield hitting the exhaust?</TD></TR></TABLE>
Yeah I know it's the tranny, because the noise goes away when I depress the clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rediness_code &raquo;</TD></TR><TR><TD CLASS="quote">This might help.
https://honda-tech.com/zerothread/1999434</TD></TR></TABLE>
Thanks for the link Red. This sounds exactly like the problem I have. I'll have to take apart my tranny one of these days when I have time and replace the mainshaft bearing.
One more question, would it be safe to drive with the mainshaft going? It isn't gone and the noise isn't that loud, but it's still there.
Old Jun 23, 2008 | 02:31 PM
When mine was messed up I drove it quite a bit, I tried not to go hard on it though.
Old Jun 23, 2008 | 04:30 PM
jdmcrx_echelon's Avatar
could be the throw out bearing... just my 2 cents
Old Jun 23, 2008 | 09:55 PM
619GSR's Avatar
the rattle at 3K is most likely the heat shield on your headers, remove the heat shield and take it for a test drive. If not that could be the heat shield on your cat.
Old Jun 27, 2008 | 05:28 PM
DC_Honda814Power_EF's Avatar
Default Re: (619GSR)
Yeah that sounds like a mainshaft bearing. I had the same problem with my civic. Dont beat on it or anything like that untill u get it replaced. After so long it will tear up ur mainshaft seal and fluid will pour into the bell housing. I know this from experience.....
civic gtr
32
Nov 4, 2004 06:51 PM
Cractos
11
Aug 26, 2004 10:33 PM
Ransom
22
Mar 15, 2004 04:06 AM
integraGSR213
Sep 11, 2003 09:49 AM
