EF Engine mounts - any need for the front gearbox mount?
Old Jun 22, 2008 | 05:44 PM
blazed_racer's Avatar
Default EF Engine mounts - any need for the front gearbox mount?
Hi guys,
I Have my EF9 pulled apart, ready for Paint, now, I have my front Cross member out, just thinking about removing the front cross member gearbox mount off completely? removing the bracket from the cross member,
I am going to replace the OEM mounts with the Innovated Billet mounts, semi race inserts, so fairly hard,
now a friend mentioned that the engine will rock back and forth alot without that front mount, any one tried removing the front mount?
any problems?
should I just keep the front mount?
Old Jun 22, 2008 | 05:49 PM
ESP.net's Avatar
Default Re: EF Engine mounts - any need for the front gearbox mount? (blazed_racer)
As a motor mount Co, you are safe with polyurethane mounts and not running the front mount they will be plenty stiff enough without the front mount.
The engine shouldn't rock back and fourth to the extreme like you mentioned you should be fine
Old Jun 22, 2008 | 07:39 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: EF Engine mounts - any need for the front gearbox mount? (ESP.net)
I think most people around here run without the front mount, when running harder mounts everywhere else.
Old Jun 22, 2008 | 08:28 PM
cool...
Yeah my friend mentioned when he ran without his, using OEM mounts, his header used to hit.
just double checked my mounts, theyre got the red inserts which are the street mounts,
you lads think these are hard enough to avoid movement?
Old Jun 22, 2008 | 08:33 PM
got another numb nut question:
the rear engine mount, how Do I unbolt that from the rear cross member?
the front bolt, no problem obviously, but the rear bolts, I can't get any tools in behind to get to them???
Do I have to drop out the Cross member?
Old Jun 22, 2008 | 09:36 PM
thedudefromjerz's Avatar
Default Re: (blazed_racer)
i got mine out with a long socket extension. just squeeze it in and manuever it onto the nut.
Old Jun 22, 2008 | 09:57 PM
silentbeatdown's Avatar
There are two ways to get that nut
A: You can crawl under the car and stick a 17mm box wrench up there from behind.
B: use a hammer to whack the mount sideways until you can see the nut.
Old Jun 22, 2008 | 10:37 PM
cool. thanks for that! will give that a go,
Old Jun 23, 2008 | 06:58 AM
Hovey's Avatar
i run with out a front mount.....motor doesnt move... i run the Innovated mounts. i like it. that rear mount can be a pain in the ***
Old Jun 23, 2008 | 06:27 PM
Hey dude,
what inserts are you running?
Old Jun 23, 2008 | 06:40 PM
gibsanez's Avatar
I'm running Innovative mounts with the 75A inserts, no front mount. At several points in my RPM range, my rear view mirror is useless because of the stiff setup and vibration.
Old Jun 25, 2008 | 04:30 AM
hmmm ok..
i think my mounts are the 60A version, street, according to IM site, can't remember now, I brought these ages ago.
Old Jun 25, 2008 | 05:58 AM
Hovey's Avatar
the 75A's should still work on urs.
Old Jun 25, 2008 | 07:23 AM
welfarepc's Avatar
if u dont need to cut it off, dont....
Old Jun 25, 2008 | 10:00 AM
AK_CRX's Avatar
Default Re: (welfarepc)
to get rear mount... use a 3/8 drive swivel extension.. The kind that can bend like 45 degrees and still turn. No hammering or taking other crap appart neccesary.
Old Jun 25, 2008 | 12:31 PM
EE2bitsk's Avatar
i put a 17 mm wrench on mine and loosened it a little, then got a hammer and tapped it sidewayz and got a socket on it and pulled it all off.
Old Jun 25, 2008 | 01:06 PM
Snafubmx234's Avatar
Default Re: (EE2bitsk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE2bitsk &raquo;</TD></TR><TR><TD CLASS="quote">i put a 17 mm wrench on mine and loosened it a little, then got a hammer and tapped it sidewayz and got a socket on it and pulled it all off.</TD></TR></TABLE>
Yup. That's what I do, mainly because I don't have a swivel extension
Old Jun 25, 2008 | 03:25 PM
cool.. cheers for all the tips and hints lads.!
Old Jun 25, 2008 | 05:29 PM
tooslohatch's Avatar
i couldnt get any swivel or anything on my rear mount. i tried for a while to. in the end i cut it off. be carefull no to hit the brake lines!! you'd be in a pickle then.
silverbullet9626
10
Apr 2, 2011 06:45 PM
es_squared
Jan 27, 2009 07:22 PM
lude98SH
Jul 8, 2007 08:34 AM
dwerpk
Dec 25, 2006 11:22 PM
0554
10
Mar 5, 2003 10:29 PM
