Wont stay started without key in "START" position
Car: 88 Civic Wagon RT4WD D16A6
Problem:
I can turn the car over, and it fires up, then dies. If I hold the key in the “start” position, it will continue running normally. I have replaced cap, rotor, wires, plug wires, and plugs today but this started before then, intermitedly. As of today, its all the time. I have tried replacing the main relay with a known good one, that didn’t help. So that leaves me with something in the actual key colum ignition system, which I am very unfamiliar with. Let me be clear, when I let the key go, its not like it stumbles and dies, its like its being turned off.
Anyone had this before, and what was the solution? I did some searching but couldn’t come up with anything concrete. Thanks for any help guys.
Problem:
^^X3... I see this problem at least 3 times a week at the Honda dealer I work at. Replace the ignition switch... that'll fix your problem!
You guys were right, I grabed one at autozone, swapped it over and its good to go. Whats weird is everyone says this is a common problem. I have had an EF of one sort or another for over 10 years now, and I have never had this problem. Never even heard of it. Cool though, thanks for the help guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCcivic91 »</TD></TR><TR><TD CLASS="quote">I grabed one at autozone</TD></TR></TABLE>
Autozone carries an ignition switch for our cars. Thats kinda shocking. Seems to me like that would be a Honda only part.
I think most people carry like 10 pounds of keys and do-dads on their key chain, probably exacerbates the problem over 20 or so years
datbuoylex69
13
Dec 12, 2002 08:43 AM
