Need a quick answer. Going from reciruclated dumptube to open. Do I need a retune?
Old Jun 22, 2008 | 01:28 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Default Need a quick answer. Going from reciruclated dumptube to open. Do I need a retune?
My dumptube goes into my downpipe at a horrible 90 degree angle. But I already forked out the $200 to get it tuned. Now I want to run an open dumptube and I'm wondering whether this will affect the tune. I dont want to spend another $200 just for a few horses of an open tube if I'll need a retune. If I'll need a retune then I'm just going to get the angle fixed at a muffler. Although I would rather have it open. So do I need a retune if I go from recirculated to open?
Modified by South Bay Surfer at 3:02 PM 6/22/2008
Old Jun 22, 2008 | 02:13 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
it would be a good idea
$200 is better than buying a new motor
Old Jun 22, 2008 | 02:27 PM
Default Re: (tannerLSt)
https://honda-tech.com/zerothread?id=1232885
In this thread, the general consensus was that when going from open to closed a retune wasn't needed. But how about the opposite--going from closed to open? Is a retune needed. Any other opinions? Any help is appreciated.
Old Jun 22, 2008 | 02:30 PM
quiksheit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">it would be a good idea
$200 is better than buying a new motor</TD></TR></TABLE>
What is your thought process behind this?
Old Jun 22, 2008 | 02:33 PM
SovXietday's Avatar
Default Re: (South Bay Surfer)
Unless your car was tuned on the absolute edge AFRs wise, I doubt you will need a retune.
Nevertheless, wouldn't hurt to check. Car might need a bit more fuel through boost, it'll be marginal at best though.
Whatever you do, make sure the tube vents in a place the turbo can't breath it in.
Old Jun 22, 2008 | 02:37 PM
Cool thanks. Before I do anything though I'll give my tuner a call and go from there. But I'm leaning towards opening it up pending his approval. There no way I'm spending another $200 when i just got it tuned a couple of days ago and for only a few horses.
Old Jun 22, 2008 | 09:29 PM
TheShodan's Avatar
Moderator
Done it a bunch. No, retuning isn't necessary, but your boost controller may need a little adjustment, since there will no longer be any backpressure issues that you previously had with the closed system.
Old Jun 22, 2008 | 09:46 PM
Default Re: (TheShodan)
I'm actually not using a boost controller. It's boosting off the wastgate spring at 9psi.
Old Jun 22, 2008 | 10:45 PM
Here is a pick of the horrible angle of the dumptube going into the downpipe. It's not quite 90 degrees but its close--between 60 and 70 degrees. What are your opinions? Should I be comcerned or should I just leave it alone. As it stands it's making 206 whp.
[IMG][/IMG]
Old Jun 23, 2008 | 06:41 AM
any opinions on the pic?
Old Jun 23, 2008 | 10:55 AM
pic is up
Old Jun 23, 2008 | 11:44 AM
LastGenEK's Avatar
I cant see any 90 degree angle in that pic, get one from under the car
Old Jun 23, 2008 | 01:03 PM
Silva Bullit DC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by South Bay Surfer &raquo;</TD></TR><TR><TD CLASS="quote"> It's not quite 90 degrees but its close--between 60 and 70 degrees. </TD></TR></TABLE>
I was considering going from open to closed, but not gonna do it now since I read that other thread you posted.
Old Jun 23, 2008 | 05:30 PM
i-want-a-crx's Avatar
Default Re: (Silva Bullit DC4)
just monitor your afr if you can.
but since you have no boost controller your fine since your wastegate will open at 9 anyways and i dont see much need for a retune since your not going to boost higher?
Old Jun 23, 2008 | 05:57 PM
neoc03's Avatar
Default Re: (i-want-a-crx)
If you have a AFR with wideband I would just watch it. I would imagine you shouldn't have any problem opening it up. I can't really see it leaning you out enough to cause any probelms.
rentacop
Honda Motorcycles
Aug 18, 2005 07:26 PM
Nims
Honda Motorcycles
17
Jul 17, 2005 08:00 PM
GruvyTune
Oct 15, 2002 05:33 PM
