my A/C smells like sh!et
Old Jul 18, 2002 | 12:57 AM
Tx92AccordExD's Avatar
Default my A/C smells like sh!et
why does my a/c smell so bad?
how can i fix this?
Old Jul 18, 2002 | 01:23 AM
Charles B.'s Avatar
Default Re: my A/C smells like sh!et (Tx92AccordExD)
what does it smell like? maybe theres a leak somewhere.
Old Jul 18, 2002 | 04:02 AM
John's Avatar
New User
It's mildew that builds up in the or vents. If you don't cycle the cold air out, condensation will build up in the vents. Before you turn off your car, you should turn off the a/c about 1-2 minutes prior and leave the vent on to cycle the air out. Also the recirculate vent function will add to this problem.
Old Jul 18, 2002 | 05:27 AM
96 SOHC VTEC's Avatar
Default Re: my A/C smells like sh!et (DunReit)
Exactly.
Old Jul 18, 2002 | 05:45 AM
4doorH22's Avatar
Default Re: my A/C smells like sh!et (96 SOHC VTEC)
If it does smell like urine though it could be that some fvcking cat sprayed your HVAC air intake right below the passenger side wiper.
Old Jul 18, 2002 | 08:04 AM
YeuEmMaiMai's Avatar
Default Re: my A/C smells like sh!et (4doorH22)
nah that would be the drunk guy next door that thought it was a toilet.....
anyways
check the drain plug on the bottom of the car, it it is plugged you are gonna have to unplug it
When you park your car after the ac is running do you get water under the car?
Old Jul 19, 2002 | 02:04 AM
Default Re: my A/C smells like sh!et (YeuEmMaiMai)
thx for the replys,
i found the problem. its my evaporator. it smelled like **** when i got to it. i flushed it out wit water. its all good now.
Old Jul 19, 2002 | 10:57 PM
TypeSH's Avatar
how do u take that out or where is it located at? I'd like to know how to take apart the AC sys to clean it up and stuff.
Old Jul 24, 2002 | 06:05 PM
mrvinyl33's Avatar
New User
Yeah, is there anything to that??
I already turn off the a/c before I stop the car and turn it back to fresh air if it already wasn't on there.
Old Jul 24, 2002 | 06:08 PM
Default Re: my A/C smells like sh!et (TypeSH)
you literally have to take apart the venter console and almost the whole dash to get to that thing
Old Jul 24, 2002 | 07:40 PM
John's Avatar
New User
I should do that with mine... even though I use it so infrequently, it's smelled pretty nasty recently...
Old Jul 29, 2002 | 05:01 PM
ExAcc's Avatar
I had a similar problem with bad smelling A/C, but not like Sh!et...honda dealer just change the filter and it has been perfec ever since...
Old Jul 29, 2002 | 09:24 PM
mrvinyl33's Avatar
New User
Default Re: my A/C smells like sh!et (ExAcc)
Which filter was this?
Old Jul 29, 2002 | 11:08 PM
r4m3n's Avatar
i had a similar thing happen to me on my accord. turns out it was not the car's problem but actually those liquid air fresheners i bought (ironic, yes)...guess the heat of the sun causes the thing to have some chemical reaction...so when i turn on the a/c, it smelled like crap...but then i had to get my air filter changed too...
Old Jul 30, 2002 | 05:25 AM
4doorH22's Avatar
Default Re: my A/C smells like sh!et (mrvinyl33)
I dunno maybe the 6th gens have some HVAC filter I don't think any earlier cars do.
Old Jul 30, 2002 | 12:47 PM
mrvinyl33's Avatar
New User
I didn't know there was one either. If so I'd like to know about it.
hoffmanp
Aug 13, 2014 08:59 PM
mario_pic
Apr 1, 2008 11:11 PM
alscrx
10
Jan 3, 2008 06:57 PM
FD3S
Feb 20, 2006 11:38 PM
