stuck in middle WIRING B18C INTO DEL SOL NON-VTEC project HELP !!!!!!!!
Old Jun 21, 2008 | 08:09 PM
250r king's Avatar
Default stuck in middle WIRING B18C INTO DEL SOL NON-VTEC project HELP !!!!!!!!
I CANT FIND A GOOD LINK OR INFO ON WIRING UP THE V-TEC AND OTHER PIN OUTS ANY INFO WILL HELP MY PROJECT IS A 93 DEL SOL NON V-TEC SWAPING IT WITH A 94 B18C V-TEC MOTOR
Old Jun 21, 2008 | 08:12 PM
z6hatchboy's Avatar
Default Re: stuck in middle WIRING B18C INTO DEL SOL NON-VTEC project HELP !!!!!!!! (250r king)
go to ffsquad.com or net then go to the tech section they have pinouts and all that
Old Jun 22, 2008 | 02:46 AM
250r king's Avatar
Default Re: stuck in middle WIRING B18C INTO DEL SOL NON-VTEC project HELP !!!!!!!! (z6hatchboy)
well still lookin for some info that site is not opened or sometin wuts a6 d4 pin outs on wut the ecu or the wire harness
Modified by 250r king at 4:20 AM 6/22/2008
Old Jun 22, 2008 | 05:17 AM
ifIexplode's Avatar
http://www.ff-squad.com/tech/w...5.jpg
http://technet.ff-squad.com/wi...s.gif
Old Jun 22, 2008 | 07:24 AM
250r king's Avatar
Default Re: (ifIexplode)
thanks i looked at the info a little late i stumbled on the site after hours of looking for it found wut the guy had said to go to but i just posted a question wut is a dual butterfly hookup
Old Jun 22, 2008 | 08:15 AM
CivicSpoon's Avatar
http://www.ff-squad.com/tech/im/p72.im_1.jpg
Found this in 2 seconds from a google search of: IAB Honda.
Old Jun 22, 2008 | 09:39 AM
250r king's Avatar
Default Re: (CivicSpoon)
alright still dont help me out im on the same site but my problem is do they have to be wired in or wut . The wire diagram shows them in yellow dots that they need to be hooked up but has the term dual butterfly hookup i dont know wut the deal is with that the others are in red
Old Jun 22, 2008 | 11:17 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: (250r king)
Answered in your other thread: https://honda-tech.com/zerothread/2327749
On the IABs, you have to either disconnect the vacuum from them, or connect the solenoid. If you do neither, then you will lose both bottom and top end power.
Old Jun 22, 2008 | 04:21 PM
CivicSpoon's Avatar
The ones in Red are for all vtec B-series engines, maybe not the Knock sensor but the rest are. If your engine has a knock sensor, then wire it up too. The ones marked with Yellow are ones that are specifically for the B18C(1) GS-R/SiR-G engine, because the other B-series engine don't have or need those wires at all (they don't have the Intake Air Bypass in their intake manifolds). So you need to wire up all the things listed in Red as well as all that are listed in Yellow. Basically they did the 2 different colors to help out everyone, not just the people doing B18C1 swaps.
Old Jun 23, 2008 | 03:13 PM
250r king's Avatar
well have another problem the clutch sensor wire where do they run too
DelSolid21
Sep 29, 2010 11:12 PM
Rthom21
Appearance Build Threads
Jun 21, 2008 07:25 PM
jbell
Feb 5, 2005 02:06 PM
corso28
Jan 3, 2004 04:57 AM
YellowR2000
Aug 17, 2001 08:23 PM
