serious problem
ok well i had to replace 2 valves on my h23a1 and i put it all back together and bought a new main relay and now i can't get my fuel pump to turn on any thoughts???
When you turn the key to on, without starting the car...does the CEL come on for 2 seconds then shut off? During that two seconds can you hear that low buzz of the fuel pump priming?
If that CEL doesn't do that, and the fuel pump doesn't prime...make sure that small ground wire attached to your thermostat housing.
That is what fixed my similar problem.
if the problem only occurs on #2, then you have a problem with either the connections, harness or computer, start by cleaning the pins on the connector, make sure it is fully plugged in and work from there.
test the voltage to a body ground at the ecu injector pins. Use the back probing method.
http://www.ff-squad.com/technet/wiring.obd1.htm
Connector A, pins 1,2,3,5
they should all show battery voltage. I am going to assume that the #2 injector pin is going to show lower voltage than the rest. If it does, then your ecu is toasted and needs to be replaced.
hmm damn i'm srry to say this but thats not it
unless i didn't do it right i put ground to the car and red to the pins unless you ment put the ground back to the ecu
Modified by ludelover88 at 4:41 PM 6/22/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludelover88 »</TD></TR><TR><TD CLASS="quote">ok now i have a new problem my number 2 cylinder will not fire i have spark and gas and when i pull the plug off it doesn't do anything help please</TD></TR></TABLE>
you said you have fuel, do you have fuel in #2 or not? pull the plug and see if you smell fuel.
if you have spark and fuel but no fire then you probably have a problem w/ compression. you did say you replaced valves right?
What valves did you replace? and was the car running before you started repairs? There are alot of things that could have been said that weren't imo. If you have fuel and fire to cyl 2 and nothing is happening then you have a compression problem imo. Check compression and make sure your spark plug is clean. I have heard cases of getting spark when grounded but none when reinstalled into the motor. Make sure you check compression.
spark plugs are new and i can hear the spark when i barly pull the boot from the plug and i'm getting compression and i replaced the intake valves on cylinder 4 and yes it was running fine before i did repairs (putting crower stage ones in and belt slipped)
thought i could have been the connector clip cuz it looked bad compared to the others and still nothing
checked the pins on the ecu all good and nothing so i'm so pissed and lost so idk
92DXinMIAMI
Jun 8, 2005 06:43 PM
