b16 turbo questions
Old Jun 21, 2008 | 05:54 PM
rustydusty1717's Avatar
Default b16 turbo questions
just wanted to ask around to see what everyone thinks on what i should run for boost on my stock b16. i'm running 6 psi right now but i'd like to run 8-10 psi. would i be able to boost 8 psi on a stock b16 with no troubles or should i just stick to 6 psi until i build the motor up a bit.
also is there any easier way to adjust boost other than a boost controller. i gotta go to college in september and just try to find cheaper ways to do stuff now. i know a boost controller would be a lot better but if there's a way to change boost without a controller that would be great.
Old Jun 21, 2008 | 06:02 PM
SovXietday's Avatar
Default Re: b16 turbo questions (rustydusty1717)
*sigh*
In short, assuming you have a common turbo or standard bolt on kit.
Yes, you can. Yes, you will need to tune for it. Just use an MBC. If you don't want a boost controller, buy a bigger spring for your wastegate. If you don't have an external wastegate, use an MBC.
And, for the record. Next time you want to ask a similar question, click the big red search button.
Old Jun 21, 2008 | 06:07 PM
sorry. i've got greddy e-manage and i know if i increase the boost i'll need to get it re-tuned. what would you say is the max psi i should run on a stock b16? i was told i should be getting a new head gasket and studs right away though. is this true?
Old Jun 22, 2008 | 09:43 PM
bump
anyone else? i need all the help i can get.
Old Jun 22, 2008 | 10:12 PM
i-want-a-crx's Avatar
Default Re: (rustydusty1717)
what i would do is get a wideband and ebc or mbs depending on your funds.
im sure turning the boost up wont hurt anything but thats what your wideband is for incase you need to make an adjustment to your a/f
but if your asking about that i think i would research and as someone said search button
Old Jun 22, 2008 | 10:34 PM
FastEg6's Avatar
Will if it's completely stock, I would get Head studs. I wouldn't suggest raising the boost until you either
A. Get it tuned for higher boost
B. Get a Manual boost controller, or electronic boost controller.
I would still get it retuned if you want to raise the boost, and get a wideband also. Better safe than sorry.
Old Jun 22, 2008 | 10:57 PM
418whpturboD's Avatar
Default Re: (FastEg6)
im runing 12psi on my b16 and all i have is hea studs and head gasket with a t61 turbo...
Old Jun 23, 2008 | 03:37 AM
Darrell Bs 10SecEG's Avatar
Im running 12psi in my 4 door Eg dailey driver.Im using a 2mm cometic headgasket,Head studs,360cc prelude injectors with a stock gsr ECU.Im running an FMU and missing link map sensor.Ive been running the same motor for 3 years now.It runs 11.90s at the track.If your running an S300 or crome,on your car,Then it should be retuned.
Old Jun 23, 2008 | 04:21 PM
so it sounds like all i need to do is head gasket and studs and i should be good for 8-10 psi? after this summer i will be doing a complete re-haul of the motor i just don't wanna blow it up by running 10 psi.
Old Jun 23, 2008 | 04:29 PM
H.A.R.T B18C1EG6's Avatar
you'll be fine. you dont need a headgasket/studs. turn up the boost and tune it
Old Jun 23, 2008 | 05:27 PM
so just make sure it's tuned good and i should be fine on a bone stock b16 for 8 psi?
BlUAc
May 20, 2006 09:43 AM
bodea_florian
Aug 25, 2004 06:54 PM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
Integra187
Sep 21, 2001 07:13 PM
