Drained block and rad of coolant. How do I refill block?
Old Jun 21, 2008 | 09:41 AM
Mikey3000's Avatar
Default Drained block and rad of coolant. How do I refill block?
I don't want to run the motor dry of coolant until the t-stat opens so how can I fill the block of coolant? I thought I heard of filling it through the t-stat housing but I don't think that'll do much as it will just fill the main coolant tube. This is a 95 H22A if that matters. TIA
Old Jun 21, 2008 | 11:14 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Drained block and rad of coolant. How do I refill block? (Mikey3000)
Start it and run it. Coolant will make its way through the block and no damage will be done.(be sure to bleed your system)
Old Jun 21, 2008 | 03:30 PM
dartonh22's Avatar
Default Re: Drained block and rad of coolant. How do I refill block? (DCFIVER)
fill it through the upper radiator hose and into the block then fill the radiator. this also helps out with bleeding
Old Jun 21, 2008 | 07:08 PM
m00nr0ck Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFIVER &raquo;</TD></TR><TR><TD CLASS="quote">(be sure to bleed your system)</TD></TR></TABLE>
make damn sure to bleed it good....pop the radiator cap and let it run for an hour while you top it off as needed....
I got stranded in houston 3 weeks ago because of this
Old Jun 22, 2008 | 06:56 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Drained block and rad of coolant. How do I refill block? (m00nr0ck Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m00nr0ck Si &raquo;</TD></TR><TR><TD CLASS="quote">
I got stranded in houston 3 weeks ago because of this </TD></TR></TABLE>
Actually most hondas have bleeder screws and it can be bled in about 15mins....
Old Jun 23, 2008 | 04:17 AM
matysik27's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFIVER &raquo;</TD></TR><TR><TD CLASS="quote">Start it and run it. Coolant will make its way through the block and no damage will be done.(be sure to bleed your system)</TD></TR></TABLE>
x2 i do this everyday at work
Old Jun 23, 2008 | 04:31 AM
Mikey3000's Avatar
Default Re: Drained block and rad of coolant. How do I refill block? (matysik27)
cool thanks guys.
arrocha87
Mar 12, 2009 11:47 AM
93(Civic)EG6
Nov 8, 2006 08:48 AM
DIRTYsouthBB6
Jul 13, 2006 09:51 AM
XxslayerxX
27
Oct 19, 2003 11:33 AM
