searched: fuel pump not priming
eh....
didnt really find anything on the search.
would it be the fuel pump itself? or what else could it be..im pretty sure its the fuel pump though. is there a different fuel pump i should use? im going to eventually put my gsr-t in there, but right now im using the dirty d as i build up the gsr-t, what fuel pump would complement both?
Check the main relay under the dash you can do that by turning the key to the on position and you should hear a clicking noise within 1-2 seconds after turning the key to the on position. Start there before assuming its the fuel pump. Good Luck
what do you mean by "not priming"
do you mean it runs but does not pump?
or do you mean "not running"?
and yeah, there is tons on here about that.
there are even current threads about it on the first page
Mine just went bad, haha. Get under the dash into the foot cowl looking up with your body mostly out the drivers side door. Look up, and to the right, you should see it held on with a 10 mm bolt. Get at it with a ratchet wrench. From there, there is ways to check continuity. If you are interested, I will post instructions on how to check.
can you please do this???? cause mine is doing the same darn thing as well.
when i go to start it the car i'll turn the key onto the on position then u can hear the fuel pump, pump the fuel, and the "click" in the dashboard. then u go to start it up, it'll start but then bog bod down and stall.
then i try to turn the key back off, turn it back on and i dont hear the fuel pump activating at all. sometimes you hear a short silent "er" like as if the fuel pump wants to activate but its not.
but i have to literally turn the key on and off, on and off and so on in order to hear the fuel pump activate and hear the click under the dash.
i sometimes even have to go under the hood and pull the battery cable off and re-attach it and that sometimes helps.
could that be the same reason? is it my main relay going as well?
It sounds like 2 of your relay actions are working but not the third. I will post the instructions up when I get home from work in about 2 hours. That and pics of my emergency roadside fix for when mine went out.
Alrite, here we go, sorry this is late, but I have been busy.
Step 1. Remove the main relay.
Step 2. Attatch the battey positive terminal to the No. 4 terminal and the battery negative terminal tothe No. 8 terminal of the main relay. Then check for continuity between the No. 5 terminal and No. 7 terminal of the main relay.
-If there is continuity, go on to step 3.
-If there is no continuity, replace the relay.
Step 3. Attatch the battey positive terminal to the No. 5 terminal and the battery negative terminal tothe No. 2 terminal of the main relay. Then check for continuity between the No. 1 terminal and No. 3 terminal of the main relay.
-If there is continuity, go on to step 4.
Step 4. Attatch the battey positive terminal to the No. 3 terminal and the battery negative terminal tothe No. 8 terminal of the main relay. Then check for continuity between the No. 5 terminal and No. 7 terminal of the main relay.
-If there is continuity, the relay is OK. If the fuel pump still does not work, you need to go on to harness testing.
Okay, so when you connect the negative and positive terminals, you don't need to exactly use a car batter. Try using a 9 volt battery, that should be strong enough to trip the relays. Also, when you test for continuity, if its not a solid 1 for impedance, then use that as its not getting continuity. If you look on the underside of the relay, there are numbers, these correspond to the terminal numbers.
Okay, so I don't know if this helps anyone, but I pulled apart my two relays that I got from the junkyard today, and on the computer board on top of the relay, one of them looked fresh and clean, and the other not so much, it looked as though the flux had spread around on top of the board. The on with the flux spread did not work in my car. Probably heat related, it made the solder connections bad.
94delsol6428
Dec 27, 2006 07:06 PM
