Can you use this to hook up your ECU and datalog with?
Old Jun 20, 2008 | 11:27 PM
TwoKSiR's Avatar
Default Can you use this to hook up your ECU and datalog with?
The NGK Powerdex AFX?
I was reading about running an LM1 through your stock ECU and reading off that instead of the stock o2.
http://passwordjdm.com/NGK-Pow....aspx
Old Jun 21, 2008 | 04:43 AM
norconex's Avatar
Default Re: Can you use this to hook up your ECU and datalog with? (TwoKSiR)
I believe the AFX only have one output and it is 0-5v.
The Innovate has two programmable outputs, one 0-1v (stock) and one 0-5v (wideband) is how they come pre-programmed.
Old Jun 21, 2008 | 09:58 AM
TwoKSiR's Avatar
Default Re: Can you use this to hook up your ECU and datalog with? (norconex)
So is that a yes you can run connect the AFX to a stock ECU?
Old Jun 21, 2008 | 10:18 AM
HRTuning's Avatar
For logging, yes, any 0-5v ranged output.
Old Jun 21, 2008 | 10:22 AM
TwoKSiR's Avatar
Default Re: Can you use this to hook up your ECU and datalog with? (HRTuning)
Thank you. I am new to Crome and tuning in general. I want to have everything before I start. I'm about to start reading the PGMFI wiki for the second time.
Old Jun 21, 2008 | 11:05 AM
98vtec's Avatar
moderator emeritus
i honestly do not like that wideband. The sampling rate is incredibly slow and it only reads from 9 to 16 AFR. The AFR skipped a lot at WOT almost like it couldn't sample fast enough.
ghosthatch
Engine Management and Tuning
30
Dec 12, 2012 04:50 AM
golfandcars
Sep 8, 2010 05:59 PM
954bballer091
Sep 13, 2008 07:38 PM
95excoupe
Feb 25, 2005 05:25 PM
