h22 not running properly
ok, i had a bad misfire issue and went through all kinds of troubles to get my car running. i replaced my plugs/wires/distributor/cap/rotor and that got rid of my crazy misfire issue. but now cylinder #4 (cam gear side) isnt working. its getting spark, i pulled the wire and heard it arcing. so now im at a loss for words. i have no other ideas as to what is wrong.
i took the spark plug out after tryin to get it running and exhaust came out the spark plug tube and it reaked of gas. so i took the valve cover off to check for a broken valve spring, none. i put the motor to TDC and the cam gears lined up perfectly. so, i have spark, i have fuel. what am i missing.
someone please help, i really dont want to take this to a shop and get raped.
check if your firing order is right. did u gap the sparkplugs?
did u do a engine wash lately? there might be a water that went inside were the sparkplugs go, if your car sounds like its a sti or has cams you might want to check that.
Dude i have the same promblem i did everything you said you did and mine is still running bad. Mine sounds like a wrx with a exhaust on it. Did you ever figure out the promblem
