RS door handles... again
ARCHIVED search, learn it, use it, love it.
Here's what I found...there are others.
https://honda-tech.com/zerothread?id=201847
is parts 10 and 29 what i need? (its on the bottom center)?
if i do the conversion, will i lose the powerlock feature? how about the keyless entry from my alarm?
sorry Im little slow today..
if you want the handle w/o switchs - part # 72125-ST7-023ZA
I bought em from acura in BC canada they were CAD$13.something each
installation? you can even do it with your foots
I was confused like you b4 for handles too
good luck~*
ps.sellin my handle with switch thing -_-;;
my alram works fine w/o the switchs
if you want to open all your doors with key
put the key into the key hol~
turn it and hold it for 1~2sec
all the doors will be unlocked
[Modified by DJHan, 11:09 AM 7/18/2002]
good luck~*
so then, i still will have power locks, just with out he chrome lever? does ur keyless entry still work?
these are like $6 each at your local acura dealer.
install in about 3.365272 seconds.
i plan to order form acura carland... they dont have the traditional product numbers... are 10 and 29 in the pic are what i need?
aren't good enough for them?
I can't tell from your diagram what 10 and 29 are. Just ask for RS non-power-lock inside door handle bezels. If they cost more than ~ $7, it's the wrong part.
you need 10 and 11. the name is door handle case or something like that. as long as you are ordering from the right group, they cost no more the $7 a piece, and you are getting a left and right, your OK. http://www.acuraautomotiveparts.net/...RONT+DOOR+LOCK
see sig.
Drinker
