t3 super 60 too small for b16?
hey guys gonna start building a turbo kit soon but wanna decide what size turbo to run first. i want a turbo that spools around 3500 and goes to redline. im looking at the t3 super 60. just wondering if that would be effecient for 250-300 whp on a stock b16
this is a old thread but check it out.
https://honda-tech.com/zerothread?id=1517049
http://www.spoolinperformance.....html
is this the turbo, cause spoolin only offers it in .48
Modified by ketchup! at 10:25 PM 6/22/2008
You have been around for 3 years and have 2500+ posts but don't know how to search?? Its about time you learned. Really. It will help you out a lot in the end.........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">why don't you get a better turbo?why don't you try a t3/t4 57 trim?</TD></TR></TABLE>
Or better yet a 50 trim if he wants faster spool on the 1.6L.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze »</TD></TR><TR><TD CLASS="quote">You have been around for 3 years and have 2500+ posts but don't know how to search?? Its about time you learned. Really. It will help you out a lot in the end.........
actually *** ive spent over 2 hours looking at turbos for b16 and doing research. i just wanted some opinions on the t3 super 60
</TD></TR></TABLE>actually *** ive spent over 2 hours looking at turbos for b16 and doing research. i just wanted some opinions on the t3 super 60
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze »</TD></TR><TR><TD CLASS="quote"> better yet a 50 trim if he wants faster spool on the 1.6L. </TD></TR></TABLE>yea that would be a better choice for the power band he is looking for
Run the larger housing if you want more topend and the smaller if you want faster spoolup. I'm sure you can find some spool times for each. If I were you I would go for the larger housing as you will likely want to max the turbo out and from the looks of the map 300hp will be about the end of the line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze »</TD></TR><TR><TD CLASS="quote">Run the larger housing if you want more topend and the smaller if you want faster spoolup. I'm sure you can find some spool times for each. If I were you I would go for the larger housing as you will likely want to max the turbo out and from the looks of the map 300hp will be about the end of the line.</TD></TR></TABLE>
The .48 a/r housing will max out pretty close to 300hp (280 i think to be exact). I'd say go for the .63 a/r and you will be able to reach your goal while not having to max out on psi.
I personally had the T3 Super 60 on my D16z6 w/ the .48 a/r and I loved it...very efficient turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware »</TD></TR><TR><TD CLASS="quote">I am looking at the exact turbo for my y8 single cam. I came up with the same info as the guy above me, if you're going for that amount of power go with the .63
I would definitely run that turbo for your Y8
</TD></TR></TABLE>I would definitely run that turbo for your Y8
I have the .63 and was originally planning on running it on my D15B Vtec. Plans have changed and it looks as though Ill be running a B16 also, so Ill post up how it works out, hopefully soon.
I had a .63/.60 T3 (not a super 60) on my ls/vtec, and the spool was instantaneous, especially compared to the Holset hx35 I just strapped on. It was a great turbo though, 1st gear was essentially useless with my B16 Trans..
