Gsr transmission pops out of reverse
Old Jun 20, 2008 | 02:44 PM
94b16teg's Avatar
Default Gsr transmission pops out of reverse
I went to back up my car today and it just keeps popping out of reverse. I goes like 3ft and pops out everytime. The werid thing is no other gears have problems just reverse I can shift 1-5 perfect, but cant back up. What could it be? Anyone ever have this problem?
Old Jun 20, 2008 | 02:53 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Gsr transmission pops out of reverse (94b16teg)
Bad engine or transmission mount? Look and see if the engine is moving a lot in the bay with the help of a friend.
Old Jun 20, 2008 | 03:49 PM
Mr_Moos's Avatar
Default Re: Gsr transmission pops out of reverse (Dogginator)
does it work if you hold it in reverse
mine did this for awhile had to take tranny out and apart the gear selector was slightly off.....
Old Jun 20, 2008 | 08:38 PM
94b16teg's Avatar
Default Re: Gsr transmission pops out of reverse (Mr_Moos)
dogginator: I have solid mound inserts. I also filled the rest up with windshield urethane. So the should be stiff.
Mr_moos: yes if I hold it back it will work but makes a crunch every few seconds(when it would have popped out if I wasnt holding it). What was off just a little?
Thanks for input from both of you guys!
Old Jun 21, 2008 | 02:55 PM
94b16teg's Avatar
anyone?
Old Jun 21, 2008 | 03:30 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94b16teg &raquo;</TD></TR><TR><TD CLASS="quote">yes if I hold it back it will work but makes a crunch every few seconds(when it would have popped out if I wasnt holding it). </TD></TR></TABLE>
Check the shift linkage first. The "crunch" could indicate internal issues.
Old Mar 8, 2011 | 05:14 PM
quartermilerun's Avatar
Hey my Gsr trans does the same thing I have all mounts except for the frontone all new mounts help please. Or does anyone kmow where I can get a GOOD ls, gsr, or b16 cable not hydro trans for around 2 or 300 bucks. Well hope you guys can help.
Old Mar 8, 2011 | 05:29 PM
11psiGSR's Avatar
Just a thought, but I had an issue similar to this a few years ago. Turns out, my transmission fluid partially drained during a clutch replacement and I never topped it back off. She was a little low, apparently. A simple drain and refill with Honda manual fluid and the issue went away completely.
Might be something to check. Good luck.
Old Mar 8, 2011 | 06:57 PM
fcm's Avatar
fcm
Old Fart
Originally Posted by 11psiGSR
Just a thought, but I had an issue similar to this a few years ago. Turns out, my transmission fluid partially drained Might be something to check. Good luck.
Ditto that^^^
It is the first thing I would check.
What year is your GS-R?
"it will work but makes a crunch every few seconds"
Not something I would want to hear in my car, a tick maybe.
I would hope it was just a bent selector fork, and possible even if all other gears work properly... #1 http://acuraautomotiveparts.org/acur...s=&view=normal but I'm thinking something more terminal.
Drain transmission oil into a pan, the drain plug should have a magnet on it, are there metal shavings on the magnet or in the pan?
You can also see how much "tranny fluid" was in it and it can't hurt to change it anyway.
If you have not already, get a look at your shift "linkage"... http://acuraautomotiveparts.org/acur...s=&view=normal ids in good working order. 94
Old Feb 28, 2014 | 09:17 AM
Soldierhot380's Avatar
I have a similar problem to this on my b18c integra. what is the best thing to do in order to fix it? It's really annoying and every time I try to reverse it make a strange loud sound like it grinding! I hope you guys can help me . Thanks!
egekreject
Aug 22, 2007 11:33 AM
JDMxNguyeN
Nov 6, 2006 11:50 PM
atmosphere
10
May 13, 2006 04:18 PM
Grip
16
Feb 5, 2004 08:55 PM
400whp
Aug 20, 2003 12:36 AM
