Change intercooler piping slightly to add fogs - retune/drawbacks
Old Jun 20, 2008 | 02:07 PM
oranginal's Avatar
Default Change intercooler piping slightly to add fogs - retune/drawbacks
Just wondering if changing the intercooler piping slightly to add some fogs would require a retune.
Also does it have any impact on airflow; since it is all compressed air does it really matter?
Here is a pic for ref, not my car but has the idea
Old Jun 20, 2008 | 07:50 PM
HiProfile's Avatar
Default Re: Change intercooler piping slightly to add fogs - retune/drawbacks (oranginal)
Keeping the same size and nearly same amount of bends wouldn't change it too much. All it would do is in/decrease pressure drop slightly, meaning the turbo will be slightly more/less efficient at a given PSI. You probably get more of a change from baro pressure changing than from the piping alterations.
Old Jun 21, 2008 | 02:08 PM
oranginal's Avatar
Default Re: Change intercooler piping slightly to add fogs - retune/drawbacks (HiProfile)
what about using a straight 90* angle bend (non curved/mandrel)
Old Jun 21, 2008 | 05:47 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oranginal &raquo;</TD></TR><TR><TD CLASS="quote">what about using a straight 90* angle bend (non curved/mandrel)</TD></TR></TABLE>
If you can avoid it you should.
Old Jun 21, 2008 | 07:33 PM
Tippyman's Avatar
Default Re: Change intercooler piping slightly to add fogs - retune/drawbacks (SovXietday)
The air would be slamming into a wall, literally. not a good idea for flow.
Old Jun 22, 2008 | 09:30 AM
oranginal's Avatar
Default Re: Change intercooler piping slightly to add fogs - retune/drawbacks (Tippyman)
what about the 90 elbow bends like in the pic, not straight 90*s
At this point i'm thinking of ditching the fogs all together.
Hard decision because once i cut that part out i can never go back without a new bumper.
b20vcrxsir
Feb 8, 2009 04:38 PM
93_teg_CT
Jun 2, 2006 11:51 PM
MooreBoost
Oct 23, 2004 09:41 AM
ebp 99 si
Oct 5, 2003 07:04 PM
FredoSP
Jul 11, 2003 03:15 AM
