ebrake light
Old Jun 19, 2008 | 06:25 PM
JDMguy88's Avatar
Default ebrake light
it seems like everytime I cold start my car, i.e. mornings, the brake light in the cluster stays on even when I put the ebrake down all the way. It stays on for quite a while and will usually turn off once I have driven for a while. I searched and it seemed like everyones fix to this problem was to add more brake fluid, but my reservoir is full... On a possibly related note in order for my ebrake to actually work I have to pull it up until it hits the arm rest... would adjusting the ebrake fix the ebrake light problem too?
Old Jun 19, 2008 | 07:56 PM
vtecb18c's Avatar
Default Re: ebrake light (JDMguy88)
yes you might need to adjust the cable
Old Jun 20, 2008 | 06:03 AM
northemt88's Avatar
pull your center console off and under it there are 2 10 or 12mm nuts on the cables and just tighten them till you only need 6 or 7 clicks then check the little plug under there that might be loose also
Old Jun 20, 2008 | 09:50 AM
JDMguy88's Avatar
Default Re: (northemt88)
Thanks guys I'll give it a whirl
Old Jun 21, 2008 | 08:58 AM
JDMguy88's Avatar
also forgot to add that after driving for a while the brake light in the cluster will turn off temporarily when the brakes are applied and then come back on when I take my foot off of the brake pedal, which leads me to believe that its not an issue with the cables, although they still need to be adjusted
lampshadej1
Nov 29, 2009 07:34 PM
not2fast
May 17, 2006 07:31 PM
AFAccord
Nov 1, 2005 02:25 PM
Charles B.
May 10, 2002 11:43 AM
joel
Dec 21, 2001 11:38 AM
