hondata with 1600cc injectors
Old Jun 19, 2008 | 03:33 PM
TokuiAutowerks's Avatar
Default hondata with 1600cc injectors
Does anyone know if hondata can support running 1600cc injectors or should I go with 1200cc ?...it will be used with e85
Old Jun 19, 2008 | 05:40 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: hondata with 1600cc injectors (TokuiAutowerks)
Not sure if it will support 1600's, but holy huge injectors batman.
Bump for a helpful answer
Old Jun 19, 2008 | 06:02 PM
95 integra's Avatar
Default Re: hondata with 1600cc injectors (SlammedDC2)
Direct from Hondata
What are the biggest injectors I can run?
The ECU can be re-calibrated to suit any sized injector (make sure you match injector impedance if you are replacing you injectors). However, injectors take a finite amount of time to open and close, so the bigger injectors tend to be less accurate with their fueling at low durations, such as idle. Much depends on the mechanics of the injector, and how quickly it can open and close. With disk type injectors (such as RC 440cc injectors) you can not tell the difference between stock injectors and injectors which flow twice as much as stock injectors, once the ECU has been reprogrammed for the larger injectors (and there is no difference on the dyno either). With race engines we have run injectors up to 4 times the size of the stock injectors.
RACEPAK
Apr 29, 2010 01:42 AM
96redgsr
Jul 21, 2004 09:46 PM
Anubyss
Jan 9, 2003 09:19 AM
b20b
Feb 5, 2002 09:14 PM
