Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Grease for brake calliper pins?
Old Jun 19, 2008 | 02:16 PM
BLKFLSH's Avatar
Default Grease for brake calliper pins?
What kind of grease would you experts recommend for the slide pins on the brake callipers? Honda's grease? Multipurpose grease? What? Thanks
Old Jun 19, 2008 | 08:12 PM
hmongboyLS's Avatar
Default Re: Grease for brake calliper pins? (BLKFLSH)
At work I just use honda high temp grease. Works fine.
Old Jun 20, 2008 | 05:05 AM
msedacca's Avatar
I do mine at a friend's Acura dealership so I use Acura grease, which is literally same thing as the Honda stuff.
Old Jun 20, 2008 | 05:47 AM
JimBlake's Avatar
Default Re: Grease for brake calliper pins? (msedacca)
I've used a few different things.
Often "multipurpose grease" is OK for those temperatures.
AutoZone-type places have "Brake Grease".
I've even used anti-seize compound & that worked OK but dried out sooner.
Old Jun 20, 2008 | 05:58 PM
BLKFLSH's Avatar
Default Re: Grease for brake calliper pins? (JimBlake)
Thanks guys. I used multipurpose grease, and was wondering if it could cause a problem.
Old Jun 20, 2008 | 06:42 PM
msedacca's Avatar
Did you replace your stock brakes with aftermarket ones? Or are you just cleaning your existing ones? I'm curious because there have been problems with some aftermarket pads and rotors.
Old Jun 21, 2008 | 12:49 PM
BLKFLSH's Avatar
All I did was change the pads (with new oem), and make sure the pins were lubed up good. The rears were pretty worn down (at 47k miles), but the fronts still have probably 10k miles left in them. Why these cars wear out the rear before the front, I don't know. Seems odd to me.
Old Jun 23, 2008 | 11:03 AM
slammed_s2k's Avatar
we use that high temp grease at our dealer..its called eurea grease
Blk2010Plt
Apr 2, 2014 07:01 AM
ScottinATL
Jun 27, 2011 05:39 AM
mike14
Apr 10, 2009 05:44 AM
HonDA INTEGRATY
Dec 5, 2008 07:22 AM
Xymox
Jan 11, 2004 05:10 PM
