help AC won't turn on!
Old Jun 19, 2008 | 01:35 PM
dc2teg2006's Avatar
Default help AC won't turn on!
Recently i converted my doors into power one, and i connected all the connectors up to the fuse box. The power on the window and locks work, but the ac dosen't turn on at all. there is one wire left that unplug under the steering column and it is a 2 pin connector (wires red/blue) and i guess that for ac? but i can't find out where to plug that one into? help out.
Old Jun 19, 2008 | 03:59 PM
tortis's Avatar
Default Re: help AC won't turn on! (dc2teg2006)
did the a/c work before you did the locks?
Old Jun 19, 2008 | 06:23 PM
dc2teg2006's Avatar
Default Re: help AC won't turn on! (tortis)
yeah, before i put in power doors, ac worked fine, even tho it blow hot air it was blowing. now it won't even turn on at all.
Old Jun 19, 2008 | 06:31 PM
tortis's Avatar
you checked your fuses? the wire that is loose , was it connected before?
tortis's Avatar
that wire may go to the fan
Old Jun 19, 2008 | 10:40 PM
dc2teg2006's Avatar
every thing work. the radio, power lock, power window, the car starts, the lights turn on but the climate control and ac does not work, i press all the button and none of it work, guess it unplugged/fuse blown? I will try to take the console apart and figure out what wire is not connected are what not, but im still trying to figure out what the 2 pin red/blue wire connected to.
Khem
May 18, 2017 02:46 PM
ef-hatchcrap
22
Sep 12, 2007 07:30 PM
SiRay6
Jul 22, 2007 05:37 PM
kin413
May 30, 2007 01:54 PM
SohcZcCrx
Apr 3, 2006 10:39 PM
