civic d16y8 HELP ME
Old Jun 19, 2008 | 12:12 PM
tdubbebawllin's Avatar
Default civic d16y8 HELP ME
i got a 98 civic and i have a problem.. i drive the car and it seems like it sputters out when i give it gas..especially past 3000 rpm.. it seems like its boggin out bad.. i mean it idles fine and dosent smoke or nohtnig.,, somebody please help me
Old Jun 19, 2008 | 12:18 PM
geneeunit's Avatar
Default Re: civic d16y8 HELP ME (tdubbebawllin)
is it throwing any codes?
Old Jun 19, 2008 | 12:29 PM
Default Re: civic d16y8 HELP ME (geneeunit)
check engine light is on ..sombody said it could be the cat.. its got a magnaflow cat on it...idkk
Old Jun 19, 2008 | 12:47 PM
any ideas
Old Jun 19, 2008 | 01:49 PM
geneeunit's Avatar
see what code the check engine light is throwing.
you can go to like autozone and use their scanner or do this::
https://honda-tech.com/zerothread/1901557
and post the code up.
Old Jun 19, 2008 | 02:02 PM
ekhatchling's Avatar
Based on your description I think its the cat too because I had the same problem. Bad cat caused back pressure, causing engine to choke after 2500rpm. But get the code checked out asap to know for sure.
Old Jun 19, 2008 | 02:57 PM
Default Re: civic d16y8 HELP ME (ekhatchling)
would that do it all at once it seems like a week ago it was fine...and where is my mass airflow.. somebody told me to take it out and clean it
Old Jun 19, 2008 | 03:27 PM
Skadaloz's Avatar
ahha..u dont have a mass air flow(maf sensor)...u have a manifold absolute pressure(map sensor)...and u dont clean the map sensor
Old Jun 19, 2008 | 03:53 PM
Default Re: civic d16y8 HELP ME (Skadaloz)
i know now.. but i checked the codes..its not showin no codes..i think it might be cat..casue i just drove it and like its fine when im drivin kinda slow... i was gettin on it and seems like when i punch the gas real quick it putters out... and then if i hold it it will catch and go back to no sputterin........
Old Jun 19, 2008 | 04:08 PM
mortificationrock's Avatar
Ok first you said you had a check engine light.
This is how you check it yourselfhttps://honda-tech.com/zerothread/1901557
After you figure out what code it is get back to us so we can help you. That link shows you how to do it and what the code means.
Old Jun 19, 2008 | 05:02 PM
Default Re: civic d16y8 HELP ME (mortificationrock)
its a o2 sensor..that wouldnt make it do that
Old Jun 19, 2008 | 06:10 PM
Well you are actually wrong. The O2 sensor causes problems like that. Replace the O2 sensor first and if that don't fix it then get back to us. Believe me I had my O2 go out and that **** made my car bogg like hell.
Old Jun 19, 2008 | 06:34 PM
tortis's Avatar
could it be the fuel filter
Old Jun 20, 2008 | 05:48 AM
Default Re: civic d16y8 HELP ME (tortis)
Man your stubborn aint you
You asked for help and it has been given to you. If you can't take a suggestion then don't post here. Evryone here will tell you to replace the O2 first and if that don't fix it then comeback. But it seems you aint able to hear suggestion, so good luck to you on figuring it out
Old Jun 20, 2008 | 11:08 AM
wtf u talkin about....i didnt say ****...i didnt ask if it could be the fuel filter.. wrong guy broo!
Old Jun 20, 2008 | 11:27 AM
del_soldude's Avatar
i gota d16z6 i swapped a y8 head on it and it did the same **** but it was the wrong cam gear throwin out the time
Old Jun 20, 2008 | 11:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdubbebawllin &raquo;</TD></TR><TR><TD CLASS="quote">wtf u talkin about....i didnt say ****...i didnt ask if it could be the fuel filter.. wrong guy broo!</TD></TR></TABLE>
My bad....my apalogies. Must have confused you cause of the noob avatar.LoL....but seriously my bad. And did you go head and change it already?
Old Jun 25, 2008 | 10:09 PM
tshuajzoo559's Avatar
You know what I have the same problem too rite now..code 65 & 91. How many o2 does the y8 have?
Laura Ilkenhans
Oct 13, 2012 06:47 AM
poop32145432
Aug 5, 2004 01:48 PM
Zorro
Jun 13, 2002 05:08 AM
EJK
Nov 14, 2001 01:34 AM
