my head is striped!
Old Jun 19, 2008 | 12:09 PM
fryguy190's Avatar
Default my head is striped!
well. here is whst happened. i had i dumbass of a mechanic do a valve adjustment on my Z6 (b/c i was to lazy to do it myself.) and when he put my valve cover back on the Dumb A$$ striped the head where the bolts go for the valve cover b/c he used a f**king impact wrench. (the bolts are fine.) so he wont fix it and now i have to. i boght the rethreader kit for it but i have no clue how it works... please help !!
Old Jun 19, 2008 | 12:15 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: my head is striped! (fryguy190)
you gob ack there and shove the rethreader kit down his throat when he refuses to do it.
but seriously, talk to his manager and if hes a manager / owner, call the BBB.
Old Jun 19, 2008 | 12:24 PM
instructor74's Avatar
for the heli coil kit use the inclosed drill bit put a dab of high temp grease on it and slowspeed drill the damaged thread out the grease will help catch the metal. Next use the tap and thread the hole you just drilled. Use grease again to catch the metal and turn it in about a 1/4 turn at a time then back it out a bit turn the tap another 1/4 turn. Take it slow you want to make sure you get a good thread cut Be careful not to bottom the tap out in the hole or it might brake. once that is done put the heli coil on the install tool and thread it in. one word of advice make sure the hole is deep enough that the heli coil is flush when installed if not you are in for a real *** pounding trying to get it out or cut the thread.
If you have a true rethreader kit you have to have some type of threads left to use it. Again use a little grease and its as easy as turning in a bolt. run it in with a wrench buy hand then remove it. Will clean up the threads and let you put the bolts back in
Old Jun 19, 2008 | 12:28 PM
fryguy190's Avatar
Default Re: my head is striped! (instructor74)
ok thanks allot man. ill be shure to get it deep enough so i dont hav to deal with it. the only thing that sucks even more though is that i have to do it five times... this blows so much... well ill update when i finish it.
Old Jun 19, 2008 | 12:32 PM
pdiggitydogg's Avatar
F that. Go back and tell them he's responsible...you dont have to fix ****.
If they dont comply tell them that youre going to file paperwork and sue. 9/10 shops will fold right there, because they'll lose in court
Old Jun 19, 2008 | 01:47 PM
Juan_Mitosis's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">F that. Go back and tell them he's responsible...you dont have to fix ****.
If they dont comply tell them that youre going to file paperwork and sue. 9/10 shops will fold right there, because they'll lose in court</TD></TR></TABLE>
%100 true. They will preassure you so you will wimp out before actually even thinking you have the law on your side. Once you show them you are FIRMLY sticking to holding them responsible, then they fold.
Volkspeed
Apr 21, 2011 09:22 AM
turboJDMeg6
Mar 28, 2005 08:21 PM
wilsel
Dec 26, 2003 08:41 AM
Type_Rydah
Dec 23, 2003 06:20 AM
stryderlis
Dec 12, 2003 07:44 PM
