Classic Hondas All Pre-1988 Hondas.
87 civic SI idle problems
Old Jun 19, 2008 | 03:04 AM
BigHenault's Avatar
Default 87 civic SI idle problems
Well just picked up a 87 civic si for my daily and it wont hold a idle when it is cold untill it is warmed up then it will jump a little bit could it be the iacv? and it is also very slugish bad injecter possibly let me no what you guys think thanks in advance.
Old Jun 19, 2008 | 07:53 AM
E-AT_me's Avatar
Default Re: 87 civic SI idle problems (BigHenault)
on these cars you can actually adjust the IACV. try that.
Old Jun 19, 2008 | 10:53 AM
cbstd's Avatar
If the timing belt is old it is possible for it to slip a tooth, causing some similar problems. I would check cam and ignition timing as well.
A can of injector cleaner might help, other wise have them cleaned and balanced if you think it is an injector problem.
Scott
Old Jun 20, 2008 | 07:52 AM
BigHenault's Avatar
Default Re: 87 civic SI idle problems (cbstd)
Fixed it today cleaned the iacv then adjusted it and ist all set!!
Vachy
Oct 10, 2013 01:35 PM
mvang001
Aug 21, 2012 07:48 AM
NoVALude
Nov 20, 2006 11:02 AM
stoopid_monkey
Apr 26, 2005 11:22 PM
REDBARON
Oct 4, 2001 07:40 PM
