Where to get crank pulley wrench?
Well, it is time to change my timing belt. Only one problem, I don't have access to an impact or a crank pulley wrench. Where can I buy a crank pulley wrench? Anybody want to get rid of their used one?
are you talking about the crank pulley holder or the crank pulley bolt wrench ?
for the wrench, you can use lug nut wrench or a 19mm, they're tque to about 130ish ft/lbs
for the holder,summit has those for 60 bucks
If you don't have to do it for another month, I can lend mine to you. Mailorder lending.
When you think about it, how many times will this wrench get used (if the ITR is your only car)? Not that often (every 60K miles)...which for the average ITR owner would probably equal once or twice. I plan on keeping my ITR forever but that's what I say today, tomorrow something could happen and I may change my mind.
When you think about it, how many times will this wrench get used?
Will
-who is leasing a wrench now for a timing belt job this weekend
If I were you I would look into renting an impact wrench ( a big one) because that damn bolt is a bitch to loosen. Even with the pulley holder I couln't do it (broke a torque bar in the process). I had to drill several holes on the side of the bolt's head to remove some contact surface between the bolt and the fat washer and finally it gave. Bought I new bolt at Acura and at least I could use the pulley to retighten it.
[Modified by JPP, 8:47 AM 7/18/2002]
