can I increase my idle by adjusting the 2 screws on the throttle wire?
Old Jun 18, 2008 | 06:22 PM
piggydog's Avatar
Default can I increase my idle by adjusting the 2 nuts on the throttle wire?
it's not the yellow arrows it's the 2 nuts right above the throttle wire and rubber thing. My car runs great, gets great mileage so I don't want to screw anything up. I just want to increase the idle so it doesn't stall on me sometimes.
Thanks
Modified by piggydog at 7:29 PM 6/18/2008
Old Jun 18, 2008 | 06:48 PM
K-Litt's Avatar
Default Re: can I increase my idle by adjusting the 2 nuts on the throttle wire? (piggydog)
There's an idle control screw on top of the throttle body right above where your intake connects.
There should be a plug for the black piece in the picture you posted. With that plug off and the engine running, you can adjust the screw I described above to set your idle where you want it. You should throw a code since that plug was disconnected, but the code will clear itself after you replace the plug.
Old Jun 19, 2008 | 10:55 AM
TruNinja619's Avatar
the 2 nuts that you're talking about is there for setting the tension/taking off excess slack for the throttle cable
Old Jun 19, 2008 | 12:23 PM
piggydog's Avatar
Default Re: (TruNinja619)
ok thanks, I thought if I tightened it a bit I might be able to increase the idle a tad
Old Jun 19, 2008 | 01:13 PM
slamdlude's Avatar
Default Re: (piggydog)
With that plug off the car will not Idle properly. That is most likely your problem to begin with. I left it unplugged before and had a very low Idle. like around 300 RPM barely running. Once I plugged it back in the problem went away.
BTW: the screw K-Litt is talking about might be covered with a black epoxy like material. It was on mine. You just need to break the epoxy or what ever it is off and adjust it that way.
Modified by slamdlude at 4:19 PM 6/19/2008
elpiar
May 8, 2006 02:30 PM
Takumi Fujiwara
Dec 25, 2005 10:26 AM
BDogggUT34
Jan 18, 2005 04:05 PM
BDogggUT34
Jan 15, 2005 10:48 AM
wantmorepower
Aug 21, 2001 12:08 PM
