clutch master cylinder
Old Jun 18, 2008 | 06:32 AM
dartonh22's Avatar
Default clutch master cylinder
i think my clutch master cylinder is leaking, but i see no visible leaks, however i let the car sit for about a month and my resevoir was empty, and after bleeding it the car deosnt really want to go into gear, what goes bad in the master cylinder.
Old Jun 18, 2008 | 08:45 AM
oranginal's Avatar
Default Re: clutch master cylinder (dartonh22)
if you master would leak it woulld be inside the cabin.
i would check the slave and see if any leaks are there.
also check the resevior and all the lines for leaks.
Old Jun 18, 2008 | 09:48 AM
Hawkze_2.3's Avatar
Yeah, check the whole length of your clutch line for leaks and check inside the cabin for a leak on the firewall where the clutch MC is.
Old Jun 18, 2008 | 10:11 AM
dartonh22's Avatar
Default Re: clutch master cylinder (Hawkze_2.3)
i was under the dash adjusting the engagement and there were no leaks, and no leaks under the resevoir, thats why i was asking if anything else goes bad besides it leaking. im most likely just gonna buy a clutch master cylinder and a slave cylinder. and see what happens
Old Jun 18, 2008 | 10:13 AM
Hawkze_2.3's Avatar
Well, if there's no leaks under the dash then that means it's somewhere along you clutch line. Follow it from the MC across the firewall and down the frame until you find the leak.
the_dxB16
Nov 30, 2008 12:51 PM
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
siregcivic
Oct 16, 2005 07:55 PM
ATS*Mark
Aug 23, 2005 09:55 AM
