PS filling question
Old Jun 18, 2008 | 05:04 AM
billyfiction's Avatar
Default PS filling question
Hi, say my steering rack is empy along with my lines ( do to working on) and my power steering pump no longer works. If I just fill my reservoir will my rack fill at all or will I have to physically pull a line and fill the the rack?
Thanks.
Old Jun 18, 2008 | 05:57 AM
Mr Yamada's Avatar
Default Re: PS filling question (billyfiction)
You can refill the reservoir with Honda power steering fluid, then start the car and turn the steering side to side [lock to lock], then shut off the engine and recheck the fluid level. Repeat this a few times.
It is common for the fluid to foam somewhat on a 'new' fill up, and you may need to let the car sit for a few hours to let the air work out of the system.
Old Jun 18, 2008 | 06:05 AM
Thanks... but say my pump is broken.. will the rack still fill with fluid by suction or is the only way for it to fill itself is with the pump?
Old Jun 18, 2008 | 06:48 AM
Mr Yamada's Avatar
Default Re: (billyfiction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billyfiction &raquo;</TD></TR><TR><TD CLASS="quote">Thanks... but say my pump is broken.. will the rack still fill with fluid by suction or is the only way for it to fill itself is with the pump?</TD></TR></TABLE>
If the pump is broken, what would be the point of adding fluid?
Old Jun 18, 2008 | 08:33 AM
so the rack doesnt seize
91_accordwagon
Jan 30, 2011 07:48 PM
vtec.dc2
Aug 1, 2006 08:16 AM
Silvteg95
Aug 3, 2005 08:28 AM
Silvteg95
Aug 1, 2005 06:59 PM
-[95cxhatch]-
Apr 12, 2004 01:38 PM
