Oil pan gasket removal
Old Jun 17, 2008 | 10:10 PM
MenaceDee's Avatar
Default Oil pan gasket removal
Replacing the gasket on the oil pan but having difficulty removing the actual gasket from the pan. Whoever did work on it before bonded the entire length of the seal and the gasket almost seems to have fused w/ the metal. I've tried using razor blades and chipping away at it but only tiny chunks are breaking apart. Does anyyone know if using Gasket Remover spray or even torching it will help?
Old Jun 17, 2008 | 10:35 PM
count me out's Avatar
* B A N N E D *
Default Re: Oil pan gasket removal (MenaceDee)
try paint stripper if its that bad.
otherwise, sit down with a 6 pack and a stack of razor blades.
Old Jun 18, 2008 | 12:05 AM
Frozen E's Avatar
H-T White Ops
wire wheel in a drill
Old Jun 18, 2008 | 02:00 AM
tortis's Avatar
Default Re: (IslandSi)
ditto on wire wheel. stuff some newspaper down in the pan to help keep the gasket out of it.
Old Jun 18, 2008 | 04:10 AM
DCSportEJ1Civic's Avatar
Default Re: (tortis)
i used a putty knife and a six pack on my buddies prelude. and a heat gun to loosen it up. it work pretty good imo.
Old Jun 18, 2008 | 05:20 AM
ricb20vtec22's Avatar
try some paint stripper or gasket remover if it's that bad. If anything you can use a drill with a wire wheel.
v8killaz
Oct 28, 2011 06:33 PM
lymanator
May 7, 2010 07:56 PM
imadigitalgod
Apr 8, 2010 09:48 AM
dth0ng69
Jul 14, 2009 08:28 PM
crumb
Apr 24, 2006 09:51 AM
