CD deck in ashtrey slot in an integra?
Old Jun 17, 2008 | 09:39 PM
jdm_dc_199's Avatar
Default CD deck in ashtrey slot in an integra?
i was wondering if anyone else had done this. and if so, how did you mount it. reason for me putting it there is so i could have a foldout screen. Thoughts, Inputs, Suggestions welcome. thanks
BTW, the big open gap is now covered with a double din ITR block-off plate.
Old Jun 17, 2008 | 09:54 PM
bmoua's Avatar
i like it...i would do the same if i had a teg and a flip out screen.
Old Jun 17, 2008 | 10:42 PM
Donnie-'s Avatar
just get a double din navi unit. solve all problems.
Old Jun 17, 2008 | 11:14 PM
jdm_dc_199's Avatar
ya but the one i want is like $1000. and i dont have the money at the moment(trying to get my car repainted). so since i already have this one, i figured i would just make this work for now.
Old Jun 18, 2008 | 03:18 PM
italianchooch88's Avatar
i did the same thing as you for my flip out..everytime i cherp gears it tends to come out..let me know if youve found a way to mount it in right
Old Jun 21, 2008 | 06:55 PM
alex_s817's Avatar
Default Re: (italianchooch88)
just go buy an "L" bracket from like home depot. find a small bolt/screw that will thread into the back of the deck (where that little mounting hole is) and then mount the other side of the bracket to the metal cross beams/bars that are back there. if because the deck sits lower the bracket will not reach, you can always buy longer/larger "L" brackets and cut them and drill them to work. just one of these tightened enough should hold everything in very tightly and keep the deck from sliding out under acceleration
Old Jun 21, 2008 | 09:23 PM
airon's Avatar
Default Re: (alex_s817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 &raquo;</TD></TR><TR><TD CLASS="quote">just go buy an "L" bracket from like home depot. find a small bolt/screw that will thread into the back of the deck (where that little mounting hole is) and then mount the other side of the bracket to the metal cross beams/bars that are back there. if because the deck sits lower the bracket will not reach, you can always buy longer/larger "L" brackets and cut them and drill them to work. just one of these tightened enough should hold everything in very tightly and keep the deck from sliding out under acceleration</TD></TR></TABLE>
same thing i did in my old gsr. my best friends are installers so they added some more back straps and other things in there that when i had to actually take it out, it was a PITA
Old Jun 21, 2008 | 10:07 PM
DynastyRacer22's Avatar
kenwood makes one that'll stick out a lil longer so it doesnt touch the ac vent so that way you dont have to modify the ash tray area
Old Jun 21, 2008 | 11:26 PM
peasoupe's Avatar
or use that aluminum plumbers tape stuff. the aluminum strips with the holes in it. i used some to secure my sub to my strut bar, worked grate. that way you dont have to mess with the length size issue, just cut to fit.
Old Jun 22, 2008 | 07:20 AM
alex_s817's Avatar
Default Re: (peasoupe)
yea thats true it will be a pain in the *** to get out, i always end up scratching/cutting the crap out of my arms lol. yea the plumbers stuff is a good idea too, would probabaly work well to attach to the sides of the deck and then run back to the metal bars. i wish there was a way to just remove those side panels so you could actually see what you were doing straight on
H9Wicked
Honda Fit
Jul 5, 2007 02:32 PM
Fuster_Cluck
Audio / Security / Video
Jan 12, 2005 05:09 AM
tekstyle
May 6, 2004 12:49 PM
julow
Oct 23, 2003 04:35 AM
Brett
Nov 18, 2002 07:05 AM
